Does anyone know what’s the official story around the loopback test failures on the LimeSDR Mini? There are at least half a dozen recent posts here describing new devices that fail the first of the two loopback tests that LimeQuickTest performs.
Some people have described consistent failures, but more common seems to be intermittent failures that may be related to temperature. My board arrived this afternoon, and I’ve been getting intermittent failures all evening.
Is this a defect on the PCB, like a cold solder joint or a short somewhere? That would suggest that there’s an external component responsible for connecting TX to RX. I’ve only skimmed the schematic, but my impression was that the switchable loopback was internal to the LMS7002. If that’s how it works, could it be a defect with the Lime IC? That seems unlikely… I guess it could be a marginal ground connection?
Maybe it’s a firmware issue or a bug in the design of the test?
Is there a bad batch, or does this happen on all of them?
Other than this intermittent loopback failure, the board appears to work. Previous commenters have suggested asking CrowdSupply for an RMA, but I don’t want to make them jump through hoops if it’s not going to fix the problem. Is it even a problem? What’s going on here?
ohazi@woodstock:~$ LimeQuickTest
->Start time: Fri May 8 00:20:27 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D588E348F8FF6
Serial Number: 1D588E348F8FF6
->REF clock test
Test results: 52661; 322; 13519 - PASSED
Results : 6711067 (min); 6711220 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 16 13 0A 16 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-48.3 dBFS, 1.36 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-15.0 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.48 seconds
->Start time: Fri May 8 00:21:09 2020
->REF clock test
Test results: 34206; 47403; 60600 - PASSED
Results : 6711047 (min); 6711200 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.6 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.7 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.46 seconds
