So this just started happening after running LimeUtil --update going from 1.28 to 1.30… The board no longer functions properly now. I barely used it four or five times.
Device Info from LimeSuiteGUI…
Firmware 6
Hardware 2
Protocol 1
Gateware 1.30
Gateware Target LimeSDR Mini
->Start time: Wed Mar 18 05:03:27 2020
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D4C299E7F215B, index=0
Serial Number: 1D4C299E7F215B
->REF clock test
Test results: 42084; 55281; 2942 - PASSED
Results : 6711071 (min); 6711225 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 02 0C 13 02 0C 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.5 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-46.5 dBFS, 1.88 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.69 seconds
