Hello, my recently purchased LimeSDR Mini intermittently fails the limequicktest Loopback Test. I’ve tried with and without an antenna, and with the device relatively cool and after it’s been on for a while. Also, Rx calibration (using SDRConsole v3) sometimes fails, with this message: “Rx calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain)”.
Some additional information:
Firmware: 6
Hardware: 3
Protocol: 1
Gateware: 1.3
Output from limequicktest:
->Start time: Sat Feb 8 20:08:34 2020
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D588FCCD7CB77, index=0
Serial Number: 1D588FCCD7CB77
->REF clock test
Test results: 54511; 2172; 15369 - PASSED
Results : 6711019 (min); 6711186 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 16 13 0A 16 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-57.3 dBFS, 2.54 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-13.1 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.43 seconds
Wondering if the board has a hardware issue, or ? Any guidance would be greatly appreciated!
