we shipped a cs-lime-12 board to our customer, but the customer told us that it is DOA with the following test results:
->Start time: Mon Nov 25 18:19:13 2019
Gateware version mismatch!
Expected gateware version 2, revision 17
But found version 2, revision 21
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=00090726074D221A, index=0
Serial Number: 00090726074D221A
->FX3 GPIF clock test
Test results: 38376; 42132; 45888 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112948 (min); 5113095 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 0C 07 12 0C 07 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-18.3 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-17.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-21.7 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-19.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.17 seconds
Is it possibly to tell from the above results that the board can be judged defective, or are there any possibilities to get it working again?
Thank you.
Adnan
