My LimeSDR USB fails every other time I access it. For example, I can run a GRC flowgraph once, but stopping and starting gives me a zero gateware version.
LimeQuickTest
->Start time: Mon Mar 30 20:22:08 2020
Read(64 bytes) failed
Gateware version mismatch!
Expected gateware version 2, revision 17
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060A02432F23
Serial Number: 0009060A02432F23
->FX3 GPIF clock test
Test results: 1; 0; 0 - PASSED
->Si5351C test
CLK0: 2 / 17554 - FAILED
CLK1: 2 / 17554 - FAILED
CLK2: 2 / 17554 - FAILED
CLK3: 2 / 17554 - FAILED
CLK4: 2 / 17554 - FAILED
CLK5: 2 / 17554 - FAILED
CLK6: 2 / 17554 - FAILED
FAILED
Results : 4 (min); 4 (max) - FAILED
FAILED
->ADF4002 Test
Error
FAILED
->Clock Network Test FAILED
->Read data: 11 02 15 11 02 15 02
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencySXT(1250 MHz) - cannot deliver frequency
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.99 seconds
Immediately rerunning the test:
LimeQuickTest
->Start time: Mon Mar 30 20:22:25 2020
Test results: 18369; 22125; 25881 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
Results : 5112916 (min); 5113046 (max) - PASSED
->ADF4002 Test
Result: 10 - PASSED
->Clock Network Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.5 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-20.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-30.7 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-13.9 dBFS, 5.00 MHz) - PASSED
Elapsed time: 1.39 seconds
Lather, rinse, repeat.
This is on a USB3 connection, with both the USB connectors plugged in, so the board should have plenty of power. I also have a fan on the board, so that it won’t overheat, and it seems to be reasonably warm, not hot.
