Hello, this this the log when I connect it cold
$ date;LimeQuickTest
Σαβ 15 Φεβ 2020 10:37:08 πμ EET
->Start time: Sat Feb 15 10:37:08 2020
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D588F01B6A2F2
Serial Number: 1D588F01B6A2F2
->REF clock test
Test results: 47682; 60879; 8540 - PASSED
Results : 6710995 (min); 6711157 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 16 13 0A 16 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-12.4 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-12.5 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.43 seconds
Without disconnecting the board, I test again after 3 minutes (Still fine)
Σαβ 15 Φεβ 2020 10:39:58 πμ EET
->Start time: Sat Feb 15 10:39:58 2020
->REF clock test
Test results: 45706; 58903; 6564 - PASSED
Results : 6711038 (min); 6711200 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-12.9 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-12.8 dBFS, 5.00 MHz) - PASSED
Elapsed time: 2.46 seconds
I wait another 3-4 mins without disconnecting the board
Σαβ 15 Φεβ 2020 10:43:33 πμ EET
->Start time: Sat Feb 15 10:43:33 2020
->REF clock test
Test results: 45962; 59159; 6820 - PASSED
Results : 6711062 (min); 6711224 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-49.4 dBFS, -1.75 MHz) - FAILED
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-13.4 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.45 seconds
When using other software without doing the test, the boards cools down quite fast on it’s own
