Hello everyone,
I have the LimeSDR-Mini 2.0 (v2.2) and when I do the LimeQuickTest I have a failure. I am using the Master repository. This is what I get :
Card15Nodd:~$ LimeQuickTest
->Start time: Sat Jan 11 12:27:45 2025
->LimeSuite version: 23.11.0-g9dce3b6a
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D90E2EE3D9564, HW=5, GW=2.2
Serial Number: 1D90E2EE3D9564
Chip temperature: 20 C
->REF clock test
Test results: 42513; 45443; 48265 - PASSED
Results : 6710993 (min); 6711029 (max) - PASSED
->Clock Network Test PASSED
FPGA EEPROM not supported in v2
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-30.4 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-20.9 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.82 seconds
Is there a problem with the card ?
Why doesn’t the test pass ?
It’s not normal to have a failure with a new item.
Everything seems ok, the failing test measurement is right on the edge of passing value (the passing value more than -30dBFS). The measurements can be affected by the temperature. You should try the test again, when the board is cold or warmed up, see if that changes the measured values.
The card is new.
I do the test when the card is cold, without antennas.
This failure bothers me a lot.
I have done a lot of testing in all conditions but it constantly fails.
Oh I missed that you have board v2.2, not the latest v2.4.
You can relax, your board is fine and within expected values. The expected value for your board version was -30±6dB.
The test is failing now because the software expected values were modified to be for the v2.4 board (changed RF test tolerance · myriadrf/LimeSuite@abc28c0 · GitHub)
This is coming from FPGA chip, PLL clocking issues can happen if it gets too hot. Generally the board should have active cooling to ensure stability.
The temperature that you see in the test is of the LMS7002M chip, but FPGA temperature is not measured and could be a lot higher. So your problems should go away if you add a fan to cool the board.
