I received the LimeSDR Mini 2.0 today, but I have an issue with the LimeQuickTest : RF Loopback Test LNA_H fails.
->Start time: Thu Feb 9 22:30:53 2023
->LimeSuite version: 22.09.1-g70e3859a
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=XXX, HW=5, GW=2.1
Serial Number: XXX
Chip temperature: 50 C
->REF clock test
Test results: 30010; 32792; 35527 - PASSED
Results : 6711043 (min); 6711077 (max) - PASSED
->Clock Network Test PASSED
FPGA EEPROM not supported in v2
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-27.8 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-23.1 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.67 seconds
I built LimeSuite from source today (master branch) on Ubuntu 22.04.
I’ve tried with and without antennas, USB 2 and USB 3 ports, with cold board (<30 degrees C). But no luck.
Does anyone know where the problem comes from ? Could it be an hardware issue ?
Thank you
