hello~
I have a limeSDR, I use it carefully, but it keeps having problems. After I removed all the antenna cables,I can’t pass the Lime SDR TestAPP when starting up.
There are problems with clock network test, LMS7002 Test, and RF loopback loop.
->Start time: Wed Dec 11 10:31:21 2019
Gateware version mismatch!
Expected gateware version 2, revision 17
But found version 257, revision 0
Lime Suite - Myriad-RF Wiki
Read(64 bytes) failed
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009072C0288261D, index=0
Serial Number: 0009072C0288261D
->FX3 GPIF clock test
->FX3 GPIF clock test FAILED
->Si5351C test
FAILED
->ADF4002 Test
FAILED
FAILED
->Clock Network Test FAILED
->Read data: 12 07 1F 12 07 1F 02
->FPGA EEPROM Test PASSED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 39.53 seconds
->Start time: Wed Dec 11 09:35:02 2019
But found version 2, revision 21
Test results: 25023; 28779; 32535 - PASSED
->Si5351C test
CLK0: 17555 / 17554 - PASSED
CLK1: 17555 / 17554 - PASSED
CLK2: 17555 / 17554 - PASSED
CLK3: 17555 / 17554 - PASSED
CLK4: 17555 / 17554 - PASSED
CLK5: 17555 / 17554 - PASSED
CLK6: 17555 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112962 (min); 5113087 (max) - PASSED
->Clock Network Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.0 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-19.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-17.0 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-19.6 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-69.4 dBFS, -19.64 MHz) - FAILED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-72.7 dBFS, -0.65 MHz) - FAILED
Elapsed time: 2.39 seconds
After the PCB is powered on for a period of time, the board becomes hot and sometimes works. If the PCB is cooled by a fan, the board will die again.
It looks like there is a problem with the circuit manufacturing soldering.
Requesting RMA
Regards
Timmy
