I purchased a LimeSDR-USB with aluminum case in late October and it is intermittently failing the quicktest, consistently on the TX_1 -> LNA_W loopback test. If I run the quicktest when the unit is first plugged in, it passes albeit with low-ish signal. However, as the unit comes up to temperature it fails consistently. This also coincides with not be able to use the LimeSuite auto-calibration (fails with error when attempted) leading me to think the unit is generally defective. Since the 90-day warranty window is at the end of January, I’d like to determine a path forward. Failing log is listed below. Thanks for the help!
Gateware version mismatch!
Expected gateware version 2, revision 17
But found version 2, revision 21
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=00090726074D041A, index=0
Serial Number: 00090726074D041A
->FX3 GPIF clock test
Test results: 26409; 30165; 33921 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112940 (min); 5113078 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 0C 06 12 0C 06 03
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-17.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-21.7 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.1 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
