Hello all,
I am debugging my own board with LMS7002M mounted on it. there is only 1.8V power supply for the LMS7002M, of course, innner LDOs are used. I only use the one RX channel to receive signal, the TX channels are closed. Currently, I find the digital RSSI changed with input analogue applitude varying. that shows the RXTSP module works fine. except the MCLK and IQsel_en signals are right in the FPGA side. the data lines are almost zeros except bit[9] of I channel, of course, even there is not input in the front LNA, the results almost is same.Now, when I changed the input from RxTSP(A/B to RNDGEN in the Limelight module, shown in the following block diagram. the results are same .
Meanwhile, I paste the ini setting in the following.
[file_info]
type=lms7002m_minimal_config
version=1
[lms7002_registers_a]
0x0020=0xFFD5
0x0021=0x0E9F
0x0022=0x57FF
0x0023=0x5550
0x0024=0xE4E4
0x0025=0x0101
0x0026=0x0101
0x0027=0xE4E4
0x0028=0x0101
0x0029=0x0101
0x002A=0x0086
0x002B=0x0038
0x002C=0x0000
0x002D=0x0641
0x002E=0x0000
0x002F=0x3841
0x0081=0x0001
0x0082=0x8001
0x0084=0x0400
0x0085=0x0001
0x0086=0x4101
0x0087=0xE353
0x0088=0x0395
0x0089=0x1090
0x008A=0x0514
0x008B=0x2136
0x008C=0x267B
0x0092=0xFFFF
0x0093=0x03FF
0x0094=0x0000
0x0095=0x0000
0x0096=0x0000
0x0097=0x0000
0x0098=0x0000
0x0099=0x6565
0x009A=0x658C
0x009B=0x6565
0x009C=0x658C
0x009D=0x6565
0x009E=0x658C
0x009F=0x658C
0x00A0=0x6565
0x00A1=0x656A
0x00A2=0x6565
0x00A3=0x6565
0x00A4=0x6565
0x00A5=0x6565
0x00A6=0x0007
0x00A7=0x6565
0x00A8=0x0000
0x00A9=0x8000
0x00AA=0x0000
0x00AB=0x0040
0x00AC=0x2000
0x00AD=0x03FB
0x00AE=0xF000
0x0100=0x3409
0x0101=0x7800
0x0102=0x3180
0x0103=0x0A12
0x0104=0x0088
0x0105=0x0011
0x0106=0x318C
0x0107=0x318C
0x0108=0xFD8C
0x0109=0x6100
0x010A=0x1F4C
0x010B=0x0001
0x010C=0x8861
0x010D=0x0198
0x010E=0x0000
0x010F=0x3142
0x0110=0x2B14
0x0111=0x0000
0x0112=0x942E
0x0113=0x03C2
0x0114=0x00D0
0x0115=0x0001
0x0116=0x8180
0x0117=0x1230
0x0118=0x018C
0x0119=0x18D2
0x011A=0x2E02
0x011C=0x9D41
0x011D=0x0000
0x011E=0x04C0
0x011F=0x3680
0x0120=0xE6B4
0x0121=0x368A
0x0122=0x0514
0x0123=0x200F
0x0124=0x0010
0x0125=0x9400
0x0126=0x12FF
0x0200=0x00E5
0x0201=0x07FF
0x0202=0x07FF
0x0203=0x7000
0x0204=0x0000
0x0205=0x0000
0x0206=0x0000
0x0207=0x0000
0x0208=0x0070
0x0209=0x0000
0x020A=0x0080
0x020B=0x4000
0x020C=0x8000
0x0240=0x0020
0x0241=0x0000
0x0242=0x0000
0x0243=0x0000
0x0244=0x0000
0x0245=0x0000
0x0246=0x0000
0x0247=0x0000
0x0248=0x0000
0x0249=0x0000
0x024A=0x0000
0x024B=0x0000
0x024C=0x0000
0x024D=0x0000
0x024E=0x0000
0x024F=0x0000
0x0250=0x0000
0x0251=0x0000
0x0252=0x0000
0x0253=0x0000
0x0254=0x0000
0x0255=0x0000
0x0256=0x0000
0x0257=0x0000
0x0258=0x0000
0x0259=0x0000
0x025A=0x0000
0x025B=0x0000
0x025C=0x0000
0x025D=0x0000
0x025E=0x0000
0x025F=0x0000
0x0260=0x0000
0x0261=0x0000
0x0280=0x0000
0x0281=0x0000
0x0282=0x0000
0x0283=0x0000
0x0284=0x0000
0x0285=0x0000
0x0286=0x0000
0x0287=0x0000
0x0288=0x0000
0x0289=0x0000
0x028A=0x0000
0x028B=0x0000
0x028C=0x0000
0x028D=0x0000
0x028E=0x0000
0x028F=0x0000
0x0290=0x0000
0x0291=0x0000
0x0292=0x0000
0x0293=0x0000
0x0294=0x0000
0x0295=0x0000
0x0296=0x0000
0x0297=0x0000
0x0298=0x0000
0x0299=0x0000
0x029A=0x0000
0x029B=0x0000
0x029C=0x0000
0x029D=0x0000
0x029E=0x0000
0x029F=0x0000
0x02A0=0x0000
0x02A1=0x0000
0x02A2=0x0000
0x02A3=0x0000
0x02A4=0x0000
0x02A5=0x0000
0x02A6=0x0000
0x02A7=0x0000
0x02C0=0x0000
0x02C1=0x0000
0x02C2=0x0000
0x02C3=0x0000
0x02C4=0x0000
0x02C5=0x0000
0x02C6=0x0000
0x02C7=0x0000
0x02C8=0x0000
0x02C9=0x0000
0x02CA=0x0000
0x02CB=0x0000
0x02CC=0x0000
0x02CD=0x0000
0x02CE=0x0000
0x02CF=0x0000
0x02D0=0x0000
0x02D1=0x0000
0x02D2=0x0000
0x02D3=0x0000
0x02D4=0x0000
0x02D5=0x0000
0x02D6=0x0000
0x02D7=0x0000
0x02D8=0x0000
0x02D9=0x0000
0x02DA=0x0000
0x02DB=0x0000
0x02DC=0x0000
0x02DD=0x0000
0x02DE=0x0000
0x02DF=0x0000
0x02E0=0x0000
0x02E1=0x0000
0x02E2=0x0000
0x02E3=0x0000
0x02E4=0x0000
0x02E5=0x0000
0x02E6=0x0000
0x02E7=0x0000
0x0300=0x0000
0x0301=0x0000
0x0302=0x0000
0x0303=0x0000
0x0304=0x0000
0x0305=0x0000
0x0306=0x0000
0x0307=0x0000
0x0308=0x0000
0x0309=0x0000
0x030A=0x0000
0x030B=0x0000
0x030C=0x0000
0x030D=0x0000
0x030E=0x0000
0x030F=0x0000
0x0310=0x0000
0x0311=0x0000
0x0312=0x0000
0x0313=0x0000
0x0314=0x0000
0x0315=0x0000
0x0316=0x0000
0x0317=0x0000
0x0318=0x0000
0x0319=0x0000
0x031A=0x0000
0x031B=0x0000
0x031C=0x0000
0x031D=0x0000
0x031E=0x0000
0x031F=0x0000
0x0320=0x0000
0x0321=0x0000
0x0322=0x0000
0x0323=0x0000
0x0324=0x0000
0x0325=0x0000
0x0326=0x0000
0x0327=0x0000
0x0340=0x0000
0x0341=0x0000
0x0342=0x0000
0x0343=0x0000
0x0344=0x0000
0x0345=0x0000
0x0346=0x0000
0x0347=0x0000
0x0348=0x0000
0x0349=0x0000
0x034A=0x0000
0x034B=0x0000
0x034C=0x0000
0x034D=0x0000
0x034E=0x0000
0x034F=0x0000
0x0350=0x0000
0x0351=0x0000
0x0352=0x0000
0x0353=0x0000
0x0354=0x0000
0x0355=0x0000
0x0356=0x0000
0x0357=0x0000
0x0358=0x0000
0x0359=0x0000
0x035A=0x0000
0x035B=0x0000
0x035C=0x0000
0x035D=0x0000
0x035E=0x0000
0x035F=0x0000
0x0360=0x0000
0x0361=0x0000
0x0362=0x0000
0x0363=0x0000
0x0364=0x0000
0x0365=0x0000
0x0366=0x0000
0x0367=0x0000
0x0380=0x0000
0x0381=0x0000
0x0382=0x0000
0x0383=0x0000
0x0384=0x0000
0x0385=0x0000
0x0386=0x0000
0x0387=0x0000
0x0388=0x0000
0x0389=0x0000
0x038A=0x0000
0x038B=0x0000
0x038C=0x0000
0x038D=0x0000
0x038E=0x0000
0x038F=0x0000
0x0390=0x0000
0x0391=0x0000
0x0392=0x0000
0x0393=0x0000
0x0394=0x0000
0x0395=0x0000
0x0396=0x0000
0x0397=0x0000
0x0398=0x0000
0x0399=0x0000
0x039A=0x0000
0x039B=0x0000
0x039C=0x0000
0x039D=0x0000
0x039E=0x0000
0x039F=0x0000
0x03A0=0x0000
0x03A1=0x0000
0x03A2=0x0000
0x03A3=0x0000
0x03A4=0x0000
0x03A5=0x0000
0x03A6=0x0000
0x03A7=0x0000
0x0400=0xB081
0x0401=0x07FF
0x0402=0x07FF
0x0403=0x7000
0x0404=0x0006
0x0405=0x0000
0x0406=0x0000
0x0407=0x0000
0x0408=0x0000
0x0409=0x0000
0x040A=0x1000
0x040B=0xAAAA
0x040C=0x0078
0x040D=0x0000
0x040E=0x2F4C
0x040F=0xD204
0x0440=0x0020
0x0441=0x0000
0x0442=0x0000
0x0443=0x0000
0x0444=0x0000
0x0445=0x0000
0x0446=0x0000
0x0447=0x0000
0x0448=0x0000
0x0449=0x0000
0x044A=0x0000
0x044B=0x0000
0x044C=0x0000
0x044D=0x0000
0x044E=0x0000
0x044F=0x0000
0x0450=0x0000
0x0451=0x0000
0x0452=0x0000
0x0453=0x0000
0x0454=0x0000
0x0455=0x0000
0x0456=0x0000
0x0457=0x0000
0x0458=0x0000
0x0459=0x0000
0x045A=0x0000
0x045B=0x0000
0x045C=0x0000
0x045D=0x0000
0x045E=0x0000
0x045F=0x0000
0x0460=0x0000
0x0461=0x0000
0x0480=0x0000
0x0481=0x0000
0x0482=0x0000
0x0483=0x0000
0x0484=0x0000
0x0485=0x0000
0x0486=0x0000
0x0487=0x0000
0x0488=0x0000
0x0489=0x0000
0x048A=0x0000
0x048B=0x0000
0x048C=0x0000
0x048D=0x0000
0x048E=0x0000
0x048F=0x0000
0x0490=0x0000
0x0491=0x0000
0x0492=0x0000
0x0493=0x0000
0x0494=0x0000
0x0495=0x0000
0x0496=0x0000
0x0497=0x0000
0x0498=0x0000
0x0499=0x0000
0x049A=0x0000
0x049B=0x0000
0x049C=0x0000
0x049D=0x0000
0x049E=0x0000
0x049F=0x0000
0x04A0=0x0000
0x04A1=0x0000
0x04A2=0x0000
0x04A3=0x0000
0x04A4=0x0000
0x04A5=0x0000
0x04A6=0x0000
0x04A7=0x0000
0x04C0=0x0000
0x04C1=0x0000
0x04C2=0x0000
0x04C3=0x0000
0x04C4=0x0000
0x04C5=0x0000
0x04C6=0x0000
0x04C7=0x0000
0x04C8=0x0000
0x04C9=0x0000
0x04CA=0x0000
0x04CB=0x0000
0x04CC=0x0000
0x04CD=0x0000
0x04CE=0x0000
0x04CF=0x0000
0x04D0=0x0000
0x04D1=0x0000
0x04D2=0x0000
0x04D3=0x0000
0x04D4=0x0000
0x04D5=0x0000
0x04D6=0x0000
0x04D7=0x0000
0x04D8=0x0000
0x04D9=0x0000
0x04DA=0x0000
0x04DB=0x0000
0x04DC=0x0000
0x04DD=0x0000
0x04DE=0x0000
0x04DF=0x0000
0x04E0=0x0000
0x04E1=0x0000
0x04E2=0x0000
0x04E3=0x0000
0x04E4=0x0000
0x04E5=0x0000
0x04E6=0x0000
0x04E7=0x0000
0x0500=0x0000
0x0501=0x0000
0x0502=0x0000
0x0503=0x0000
0x0504=0x0000
0x0505=0x0000
0x0506=0x0000
0x0507=0x0000
0x0508=0x0000
0x0509=0x0000
0x050A=0x0000
0x050B=0x0000
0x050C=0x0000
0x050D=0x0000
0x050E=0x0000
0x050F=0x0000
0x0510=0x0000
0x0511=0x0000
0x0512=0x0000
0x0513=0x0000
0x0514=0x0000
0x0515=0x0000
0x0516=0x0000
0x0517=0x0000
0x0518=0x0000
0x0519=0x0000
0x051A=0x0000
0x051B=0x0000
0x051C=0x0000
0x051D=0x0000
0x051E=0x0000
0x051F=0x0000
0x0520=0x0000
0x0521=0x0000
0x0522=0x0000
0x0523=0x0000
0x0524=0x0000
0x0525=0x0000
0x0526=0x0000
0x0527=0x0000
0x0540=0x0000
0x0541=0x0000
0x0542=0x0000
0x0543=0x0000
0x0544=0x0000
0x0545=0x0000
0x0546=0x0000
0x0547=0x0000
0x0548=0x0000
0x0549=0x0000
0x054A=0x0000
0x054B=0x0000
0x054C=0x0000
0x054D=0x0000
0x054E=0x0000
0x054F=0x0000
0x0550=0x0000
0x0551=0x0000
0x0552=0x0000
0x0553=0x0000
0x0554=0x0000
0x0555=0x0000
0x0556=0x0000
0x0557=0x0000
0x0558=0x0000
0x0559=0x0000
0x055A=0x0000
0x055B=0x0000
0x055C=0x0000
0x055D=0x0000
0x055E=0x0000
0x055F=0x0000
0x0560=0x0000
0x0561=0x0000
0x0562=0x0000
0x0563=0x0000
0x0564=0x0000
0x0565=0x0000
0x0566=0x0000
0x0567=0x0000
0x0580=0x0000
0x0581=0x0000
0x0582=0x0000
0x0583=0x0000
0x0584=0x0000
0x0585=0x0000
0x0586=0x0000
0x0587=0x0000
0x0588=0x0000
0x0589=0x0000
0x058A=0x0000
0x058B=0x0000
0x058C=0x0000
0x058D=0x0000
0x058E=0x0000
0x058F=0x0000
0x0590=0x0000
0x0591=0x0000
0x0592=0x0000
0x0593=0x0000
0x0594=0x0000
0x0595=0x0000
0x0596=0x0000
0x0597=0x0000
0x0598=0x0000
0x0599=0x0000
0x059A=0x0000
0x059B=0x0000
0x059C=0x0000
0x059D=0x0000
0x059E=0x0000
0x059F=0x0000
0x05A0=0x0000
0x05A1=0x0000
0x05A2=0x0000
0x05A3=0x0000
0x05A4=0x0000
0x05A5=0x0000
0x05A6=0x0000
0x05A7=0x0000
0x05C0=0x00FF
0x05C1=0x0000
0x05C2=0x0000
0x05C3=0x0000
0x05C4=0x0000
0x05C5=0x0000
0x05C6=0x0000
0x05C7=0x0000
0x05C8=0x0000
0x05C9=0x0000
0x05CA=0x0000
0x05CB=0x2020
0x05CC=0x0000
0x0600=0x0F00
0x0601=0x003F
0x0602=0x2000
0x0603=0x0000
0x0604=0xFFFF
0x0605=0x205D
0x0606=0xFFFF
0x0640=0x80A0
0x0641=0x1020
[lms7002_registers_b]
0x0100=0x340E
0x0101=0x7800
0x0102=0x3180
0x0103=0x0A12
0x0104=0x0088
0x0105=0x001E
0x0106=0x318C
0x0107=0x318C
0x0108=0x958C
0x0109=0x61C1
0x010A=0x104C
0x010B=0x0000
0x010C=0x88FE
0x010D=0x009E
0x010E=0x2040
0x010F=0x30C6
0x0110=0x0994
0x0111=0x0083
0x0112=0xC0E6
0x0113=0x03C3
0x0114=0x008D
0x0115=0x000E
0x0116=0x8180
0x0117=0x280C
0x0118=0x018C
0x0119=0x528B
0x011A=0x2E02
0x011C=0x8941
0x011D=0x0000
0x011E=0x0650
0x011F=0x3600
0x0120=0xE6B4
0x0121=0x82D8
0x0122=0x0514
0x0123=0x200F
0x0124=0x001F
0x0125=0x9400
0x0126=0x12FF
0x0200=0x0080
0x0201=0x07FF
0x0202=0x07FF
0x0203=0x0000
0x0204=0x0000
0x0205=0x0000
0x0206=0x0000
0x0207=0x0000
0x0208=0x01FB
0x0209=0x0000
0x020A=0x0080
0x020B=0x4000
0x020C=0x0000
0x0240=0x0020
0x0241=0x0000
0x0242=0x0000
0x0243=0x0000
0x0244=0x0000
0x0245=0x0000
0x0246=0x0000
0x0247=0x0000
0x0248=0x0000
0x0249=0x0000
0x024A=0x0000
0x024B=0x0000
0x024C=0x0000
0x024D=0x0000
0x024E=0x0000
0x024F=0x0000
0x0250=0x0000
0x0251=0x0000
0x0252=0x0000
0x0253=0x0000
0x0254=0x0000
0x0255=0x0000
0x0256=0x0000
0x0257=0x0000
0x0258=0x0000
0x0259=0x0000
0x025A=0x0000
0x025B=0x0000
0x025C=0x0000
0x025D=0x0000
0x025E=0x0000
0x025F=0x0000
0x0260=0x0000
0x0261=0x0000
0x0280=0xCAAA
0x0281=0x482C
0x0282=0x3A92
0x0283=0xFCE7
0x0284=0x15C4
0x0285=0x4D54
0x0286=0x1B8D
0x0287=0x2034
0x0288=0x48CD
0x0289=0x04A0
0x028A=0x2E30
0x028B=0xDC83
0x028C=0x0319
0x028D=0x8C0C
0x028E=0x5FB8
0x028F=0x41E2
0x0290=0x6B41
0x0291=0x6308
0x0292=0x7DC5
0x0293=0x7249
0x0294=0x9154
0x0295=0xCCAA
0x0296=0x658A
0x0297=0xFCF1
0x0298=0xA521
0x0299=0x8D70
0x029A=0x0152
0x029B=0x4638
0x029C=0x6BBB
0x029D=0x4581
0x029E=0xE65A
0x029F=0x2C03
0x02A0=0x4049
0x02A1=0x8C06
0x02A2=0x0D80
0x02A3=0x703A
0x02A4=0x0270
0x02A5=0x2907
0x02A6=0xA409
0x02A7=0xC081
0x02C0=0x14FA
0x02C1=0x4552
0x02C2=0x2116
0x02C3=0x7208
0x02C4=0x238F
0x02C5=0x5290
0x02C6=0x30CB
0x02C7=0x9589
0x02C8=0xB410
0x02C9=0x48E5
0x02CA=0x108B
0x02CB=0x397A
0x02CC=0x3385
0x02CD=0x945C
0x02CE=0x3B0B
0x02CF=0x2188
0x02D0=0x4A6C
0x02D1=0xE30B
0x02D2=0x4C12
0x02D3=0x71A0
0x02D4=0x6C49
0x02D5=0x30DD
0x02D6=0x1C2C
0x02D7=0x9D89
0x02D8=0x0C69
0x02D9=0x0F04
0x02DA=0x1D41
0x02DB=0xC8D1
0x02DC=0x9D8D
0x02DD=0xAAE6
0x02DE=0x4D5F
0x02DF=0x3C2D
0x02E0=0x9542
0x02E1=0x36F8
0x02E2=0x1A73
0x02E3=0x9408
0x02E4=0x5360
0x02E5=0xD5ED
0x02E6=0x8186
0x02E7=0xF909
0x0300=0x9633
0x0301=0xA864
0x0302=0x90D8
0x0303=0x99C9
0x0304=0x849A
0x0305=0x5063
0x0306=0xDA17
0x0307=0x9930
0x0308=0xCCDE
0x0309=0x7062
0x030A=0x8F81
0x030B=0xBFB4
0x030C=0xB275
0x030D=0x2983
0x030E=0x0698
0x030F=0x9C33
0x0310=0xB9A3
0x0311=0xC91A
0x0312=0x1675
0x0313=0x580D
0x0314=0xA1A0
0x0315=0xE03C
0x0316=0xC9A0
0x0317=0xECC5
0x0318=0xAA4A
0x0319=0x8560
0x031A=0x0B58
0x031B=0x8032
0x031C=0x04B5
0x031D=0xC103
0x031E=0xA8BF
0x031F=0x9326
0x0320=0x4F42
0x0321=0x9C52
0x0322=0xC191
0x0323=0x8400
0x0324=0x621D
0x0325=0x486D
0x0326=0xC5CC
0x0327=0x0010
0x0340=0x26AC
0x0341=0x01C1
0x0342=0xAF92
0x0343=0x9C96
0x0344=0x3C18
0x0345=0xA64D
0x0346=0xBDC1
0x0347=0x2120
0x0348=0xC63E
0x0349=0x6002
0x034A=0x9018
0x034B=0x271C
0x034C=0xA9EC
0x034D=0x75D1
0x034E=0x1A1E
0x034F=0x4024
0x0350=0x7D2A
0x0351=0xC98A
0x0352=0x0F55
0x0353=0x34C9
0x0354=0x01F5
0x0355=0x3005
0x0356=0xA31B
0x0357=0xE870
0x0358=0x8788
0x0359=0x45A0
0x035A=0xC47D
0x035B=0x489C
0x035C=0x7503
0x035D=0x6398
0x035E=0x9098
0x035F=0x4582
0x0360=0x9C10
0x0361=0xC210
0x0362=0x6AC4
0x0363=0x7213
0x0364=0x11CE
0x0365=0x351A
0x0366=0x5281
0x0367=0x9851
0x0380=0x1E74
0x0381=0x4124
0x0382=0xF029
0x0383=0x604F
0x0384=0x3492
0x0385=0x16E8
0x0386=0x0AE2
0x0387=0x26A2
0x0388=0x1051
0x0389=0xBA14
0x038A=0x7140
0x038B=0x2022
0x038C=0x2C4A
0x038D=0x912A
0x038E=0xA79D
0x038F=0x2643
0x0390=0x2610
0x0391=0xCC43
0x0392=0xE131
0x0393=0x10E6
0x0394=0x6E05
0x0395=0x4C00
0x0396=0x4740
0x0397=0x5918
0x0398=0x0387
0x0399=0x211E
0x039A=0x6222
0x039B=0x3042
0x039C=0x98B4
0x039D=0xCBAC
0x039E=0x4E54
0x039F=0x2E40
0x03A0=0x0834
0x03A1=0x2C6E
0x03A2=0x1022
0x03A3=0x29C6
0x03A4=0x5639
0x03A5=0x8880
0x03A6=0x0CB1
0x03A7=0x41AA
0x0400=0x0080
0x0401=0x07FF
0x0402=0x07FF
0x0403=0x0000
0x0404=0x0000
0x0405=0x0000
0x0406=0x0000
0x0407=0x0000
0x0408=0x0000
0x0409=0x0000
0x040A=0x2000
0x040B=0x0000
0x040C=0x01FF
0x040D=0x0000
0x040E=0x0000
0x040F=0x0000
0x0440=0x0020
0x0441=0x0000
0x0442=0x0000
0x0443=0x0000
0x0444=0x0000
0x0445=0x0000
0x0446=0x0000
0x0447=0x0000
0x0448=0x0000
0x0449=0x0000
0x044A=0x0000
0x044B=0x0000
0x044C=0x0000
0x044D=0x0000
0x044E=0x0000
0x044F=0x0000
0x0450=0x0000
0x0451=0x0000
0x0452=0x0000
0x0453=0x0000
0x0454=0x0000
0x0455=0x0000
0x0456=0x0000
0x0457=0x0000
0x0458=0x0000
0x0459=0x0000
0x045A=0x0000
0x045B=0x0000
0x045C=0x0000
0x045D=0x0000
0x045E=0x0000
0x045F=0x0000
0x0460=0x0000
0x0461=0x0000
0x0480=0x7CDA
0x0481=0x40A3
0x0482=0x97B5
0x0483=0xCD3B
0x0484=0x4011
0x0485=0xE746
0x0486=0x68C8
0x0487=0x8BC3
0x0488=0x484E
0x0489=0x6CC7
0x048A=0xA9F9
0x048B=0x88E6
0x048C=0x92E6
0x048D=0x9605
0x048E=0x263D
0x048F=0x27EE
0x0490=0x9E66
0x0491=0x0914
0x0492=0x2027
0x0493=0xD45D
0x0494=0xD1A1
0x0495=0xDFEE
0x0496=0xFE8F
0x0497=0xCD2F
0x0498=0x9D42
0x0499=0x25EA
0x049A=0xFF13
0x049B=0xB81E
0x049C=0x3A72
0x049D=0x197C
0x049E=0x4611
0x049F=0x24E1
0x04A0=0x35D6
0x04A1=0x16CE
0x04A2=0x1C11
0x04A3=0xB2D9
0x04A4=0x2BC1
0x04A5=0xAD8D
0x04A6=0xF798
0x04A7=0x7925
0x04C0=0x4569
0x04C1=0x4B22
0x04C2=0x81CB
0x04C3=0x8ABC
0x04C4=0xF117
0x04C5=0xE76B
0x04C6=0x4F9C
0x04C7=0x3D38
0x04C8=0xA04F
0x04C9=0xC7A4
0x04CA=0x813E
0x04CB=0x6AEF
0x04CC=0x4A91
0x04CD=0x9D00
0x04CE=0x3CB4
0x04CF=0x214D
0x04D0=0xE0A5
0x04D1=0xF1D5
0x04D2=0x7737
0x04D3=0xFA8F
0x04D4=0xF082
0x04D5=0x90FE
0x04D6=0xA2FB
0x04D7=0x1EDD
0x04D8=0x2DFF
0x04D9=0x0B0D
0x04DA=0x73FD
0x04DB=0x850B
0x04DC=0xF0E8
0x04DD=0x202E
0x04DE=0xF78D
0x04DF=0x9342
0x04E0=0xA0F3
0x04E1=0xAD8D
0x04E2=0x9B82
0x04E3=0x1BD8
0x04E4=0x6EC5
0x04E5=0xF3A4
0x04E6=0xB07C
0x04E7=0x02B0
0x0500=0x1151
0x0501=0x7499
0x0502=0x3FE1
0x0503=0x87CD
0x0504=0x35B9
0x0505=0x3D71
0x0506=0x6AF5
0x0507=0xBD12
0x0508=0x02EC
0x0509=0x66A9
0x050A=0x6937
0x050B=0x2F7F
0x050C=0x6A05
0x050D=0x1613
0x050E=0xD558
0x050F=0xF444
0x0510=0xB303
0x0511=0xEECC
0x0512=0x7ED5
0x0513=0xB67D
0x0514=0x8E69
0x0515=0x2FE3
0x0516=0x3E87
0x0517=0xBA74
0x0518=0xC267
0x0519=0xF958
0x051A=0x49B7
0x051B=0xB860
0x051C=0x527D
0x051D=0x06F8
0x051E=0xEDA3
0x051F=0xF584
0x0520=0x7343
0x0521=0x717F
0x0522=0xCADB
0x0523=0xC493
0x0524=0x726F
0x0525=0xF470
0x0526=0x06EF
0x0527=0xD9CE
0x0540=0xE699
0x0541=0x2227
0x0542=0xBEC1
0x0543=0x7E34
0x0544=0xC534
0x0545=0x52A7
0x0546=0x0787
0x0547=0xB063
0x0548=0xEBDE
0x0549=0x43D4
0x054A=0x4DC5
0x054B=0x7FFD
0x054C=0x6874
0x054D=0xAED6
0x054E=0xA6F3
0x054F=0x5E8E
0x0550=0x69AE
0x0551=0xF587
0x0552=0x8E1B
0x0553=0x616E
0x0554=0x81D3
0x0555=0x0B45
0x0556=0x89D6
0x0557=0xE831
0x0558=0x042C
0x0559=0xDBB9
0x055A=0x3BBC
0x055B=0x2A8A
0x055C=0x5F71
0x055D=0xF063
0x055E=0xF0A5
0x055F=0x6498
0x0560=0x8C7F
0x0561=0x30C8
0x0562=0x0BEF
0x0563=0x6B35
0x0564=0xB4DC
0x0565=0x541B
0x0566=0x7943
0x0567=0x3BB0
0x0580=0x406D
0x0581=0x5862
0x0582=0x92F6
0x0583=0xA9F5
0x0584=0xFA4C
0x0585=0x4594
0x0586=0x29EB
0x0587=0xDB53
0x0588=0x6DAD
0x0589=0x3869
0x058A=0x575D
0x058B=0x3D6E
0x058C=0x25A6
0x058D=0xE94B
0x058E=0x0D19
0x058F=0x33EC
0x0590=0x609F
0x0591=0x8DCE
0x0592=0x14CD
0x0593=0x7252
0x0594=0x7319
0x0595=0x18AF
0x0596=0x8236
0x0597=0x55C3
0x0598=0x4EC9
0x0599=0x1A55
0x059A=0xA796
0x059B=0xE70C
0x059C=0xEB1F
0x059D=0xE1E8
0x059E=0xE8C6
0x059F=0x475B
0x05A0=0x80FD
0x05A1=0xB4D5
0x05A2=0xA4F6
0x05A3=0x8FBD
0x05A4=0xFC64
0x05A5=0x87DB
0x05A6=0xAD50
0x05A7=0x31CC
0x0600=0x0F00
0x0601=0x003B
0x0602=0x2000
0x0603=0x0000
0x0604=0xFFFF
0x0605=0x205D
0x0606=0xFFFF
0x0640=0x80A0
0x0641=0x1020
[reference_clocks]
sxt_ref_clk_mhz=40
sxr_ref_clk_mhz=40
I used RX channel A.
Could you pls help me to check it, and give me some advice? thanks very much!
Best Regards!
@Zack
@ ricardas
