Soapy Lime and Ubuntu 16.04?
Here have recent fresh Ubuntu 16.04 re-installation.
All in relation to soapy have started with SDRPlay RSP1 and Cubic 2.02 working ok
Later have installed LimeSuite, working ok,
and SDRAngel working ok with Lime and RSP1
During the installation of https://osmocom.org/projects/osmotrx/wiki/LimeSDR
have find out that LimeUtil --find can see my Lime
but
SoapySDRUtil --find can not see my Lime
After all trials to reinstall in accordance to known how-to instructions
like -> https://github.com/pothosware/PothosCore/wiki/Ubuntu
still no luck
While this may be for a later version of Ubuntu, the sequence won’t be much different. I have a post on this and will add that as soon as I come across it (it was for Ubuntu 16.04)…Standby for more…
when installing LimeSuite from packages, I think you also need to install lms7 support for SoapySDR:
apt-get install soapysdr-module-lms7
Maybe, you are missing it?
Thank you Marty…
Fact is that I managed to run smooth all of lime related on 17.04
and because of osmotrx and SDRPlay which was not able to run both RSP1
decided to try with 16.04
RSP1 doing good, but Lime and soapy no luck
Any way must, try once more in accordance to order on your link…
Finally able to jump in OsmoTrx puzzle…
I see over there you are helping to make Lime live under OsmoTRX http://git.osmocom.org/osmo-trx/log/
tnx for that too
BRG Djani
PS
this is what is at the moment my major target for Lime
