Please help with a few questions while trying to get LimeSDR-USB with SoapySDR working. I used apt-get to install all and on Ubuntu 16.04.7 LTS
- .so Error do I need to be concerned with this?
SoapySDRUtil --probe
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules0.7/libLMS7Support.so)
duplicate entry for lime (/usr/lib/x86_64-linux-gnu/SoapySDR/modules0.7/libLMS7Support.so)
I installed using the following:
From https://wiki.myriadrf.org/Lime_Suite
sudo apt-get update
sudo apt-get install limesuite liblimesuite-dev limesuite-udev limesuite-images
sudo apt-get install soapysdr-tools soapysdr-module-lms7
- How do I get gateware to 22?
Expected gateware version 2, revision 22
But found version 2, revision 20
- Soapy doesn’t see LimeSDR-USB (SopySDRUtil --probe) if soapysdr is installed, SoapySDR only sees LimeSDR-USB if soapysdr-tools is installed. OK?
Thanks for the help!
Dan
