I have had the system working a while back - been away from it for about a yr. Now re-install a clean Ubuntu, install the drivers / etc (Soapy, LimeSuite, …) and trying to get up and running. BUT gqrx, cubic, and others don’t see the device??
I have followed the details on the forum, or at least the ones that I have found. BUT I can’t for the life of me figure it out. REALLY could use a nudge in the right direction pls.
I am not sure what exactly the problem is, but yiu have to install Soapy and Lime in the correct order. Maybe this is the problem. I wrote a simple bash script for it, maybe you can try it with a fresh install:
#!/bin/sh
if [ “$(id -u)” == “0” ]; then
echo “This script must be run as normal User” 1>&2
exit 1
fi
