I just received my LimeSdr, and so far I wasn’t able to use it as intended through GNURADIO.
I followed these steps to install the packages on a new Ubuntu 16.04:
sudo apt install python-pip
sudo apt install python3-pip
sudo pip install pybombs
pybombs recipes add gr-recipes git+https://github.com/gnuradio/gr-recipes.git
mkdir prefix/
pybombs prefix init -a default prefix/default/ -R gnuradio-default
pybombs install gr-osmosdr
cd prefix/default
source ./setup_env.sh
sudo apt-get update
sudo apt-get install limesuite liblimesuite-dev limesuite-udev limesuite-images
LimeUtil --find
gnuradio-companion
LimeUtil --update
when I type
“LimeUtil –find” On terminal
I get : [LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009070105C52E12]
but with:
“SoapySDRUtil –info”
I get
Lib Version: v0.7.0-g824d83e8
API Version: v0.7.0
ABI Version: v0.7
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.7
No modules found!
Available factories… No factories found!
Available converters…
- CS32 -> [CS32]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- S32 -> [S32]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
So it seems that the SoapySDR_0.7 is not recognizing my board
I’ve read somewhere that this might be an issue due to the incompatibility with the SoapySDR_0.7 version?
Any Helps??
