After the cypress driver installation, in the device manager i can see “Cypress FX2LP No EEPROM Device”.
Is it normal ?
PS : My OS is windows 7 64bits.
Hi ritchy,
What board are you using?
Rich
Digital Interface V1.0
Hey,
Have you checked de0nao repository for the necessary files:
Rich
thanks for your reply.
Well, in fact i have many questions, and please tell me if i m wrong.
If i don’t use FPGA, i should be able to test LMS6002 registers? Because, there is a bug when i launch “test registers”. Sometimes, i must disconnect usb cable cause the program won’t respond after launching else it says “Fail” on all test. What s going on?
Nothing happened on SCLK pin of the I²C to SPI chip. -
What s the exact purpose of FPGA? I see there are spi master, i²C slave to control lms registers but if main board does that, why using the FPGA to do the same?
I 'm sorry to ask stupid questions. : )
cheers
