I just checked setup - everything works ass expected in my case. Make sure that folders “fx2lib” and “usbio_1v08” are in the same folder. Another issue might be version of make. Just make sure you’ve followed cygwin install instructions, especially Figure 19 in page 13 of the FX2LP guide 1.00r08.pdf document.
Print screen of my setup as an evidence is there (setup.png):
In the fx2_sdk_kit folder from the above link you will find the firmware, SDCC, cygwin, documentation - everything you need to compile the firmware successfully.
Appreciate your reply. Actually, I have complete the firmware program, but I want to do is duplicating the environment to modify cypress open source code.
Have you set up the environment? I have try two system windows 7 64-bit and windows xp 32-bit, all of them are fail to do “make”. There are some problems as below list.
there is no “fx2.mk” file
fx2types.h seems cannot be compiled, there has a error in “at” and “xdata”
The document describe usbio_1v08, however there is only usb_1v06 in website for download.
sdcc 2.90 does not include “sdas8051.exe” command
Unfortunately, I still can not complete compilation until now. Hope to get more information.
