update: I de-installed the PothosSDR (2020 version) and I installed the 2019.03.24 version of pothosSDR - and wanted to test using an earlier code base. The gateware and firmware were downgraded.
PS C:\Users\Eva> LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9060B00491B2A]
Existing firmware is same as update (4)
Existing gateware is same as update (2.20)
Firmware and Gateware update is not required.
So, if I run the LimeQuickTest now, no output is observed in Windows 10 power shell, but I don’t know if that is because this older LimeQuickTest is functional or not.
I can however (obviously) load up PothosSDR environment and create flow-graphs.
I observe the FPGA device running relatively warm, though I am not doing anything. (It’s just plugged in). Is this normal?
Would anyone have a Hello World tutorial for Tx/Rx to check out photosSDR and LimeSDR-USB?
Thanks.
PS C:\Users\Eva> SoapySDRUtil --probe="driver=lime"
Probe device driver=lime
[INFO] Make connection: 'LimeSDR-USB [USB 3.0] 9060B00491B2A'
[INFO] Reference: 30.72 MHz
e[1me[31m[ERROR] SetPllFrequency: error configuring phasee[0m
-- Device identification
driver=FX3
hardware=LimeSDR-USB
boardSerialNumber=0x491b2a
firmwareVersion=4
gatewareVersion=2.20
hardwareVersion=4
protocolVersion=1
-- Peripheral summary
Channels: 2 Rx, 2 Tx
Timestamps: YES
Sensors: clock_locked, lms7_temp
Registers: BBIC, RFIC0
GPIOs: MAIN
-- RX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream formats: CF32, CS12, CS16
Native format: CS16 [full-scale=2048]
Stream args:
* Buffer Length - The buffer transfer size over the link.
[key=bufferLength, units=samples, default=0, type=int]
* Link Format - The format of the samples over the link.
[key=linkFormat, default=CS16, type=string, options=(CS16, CS12)]
* Skip Calibration - Skip automatic activation calibration.
[key=skipCal, default=false, type=bool]
Antennas: NONE, LNAH, LNAL, LNAW, LB1, LB2
Corrections: DC removal, DC offset
Full gain range: [-12, 61] dB
TIA gain range: [0, 12] dB
LNA gain range: [0, 30] dB
PGA gain range: [-12, 19] dB
Full freq range: [0, 3800] MHz
RF freq range: [30, 3800] MHz
BB freq range: [-10, 10] MHz
Tune args:
[key=OFFSET, units=Hz, default=0.0, type=float, range=[-1e+07, 1e+07]]
[key=BB, units=Hz, default=DEFAULT, type=float, range=[-1e+07, 1e+07], options=(DEFAULT, IGNORE)]
Sample rates: [0.1, 65] MSps
Filter bandwidths: [1.4, 130] MHz
Sensors: lo_locked
Other Settings:
* TSP DC Level - Digital DC level in LMS7002M TSP chain.
[key=TSP_CONST, type=int, range=[0, 32767]]
-- RX Channel 1
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
-- TX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream args:
Antennas: NONE, BAND1, BAND2
Corrections: DC offset
Full gain range: [-12, 64] dB
PAD gain range: [0, 52] dB
IAMP gain range: [-12, 12] dB
Tune args:
Filter bandwidths: [5, 40], [50, 130] MHz
Sensors: lo_locked
Other Settings:
-- TX Channel 1
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
