Purchased two LimeSDR-USB models and received them on 6/12. Both act very differently from each other. Running LimeQuickTest on the one I believe is defective yields different results almost every time and the board fails…
Here are the typical results:
->Start time: Mon Jun 15 15:16:09 2020
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009081C05C41211, index=0
Serial Number: 0009081C05C41211
->FX3 GPIF clock test
Test results: 39328; 43084; 46840 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112936 (min); 5113080 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 01 1C 13 01 1C 04
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
SetPllFrequency: error configuring phase
LML RX phase search FAIL
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.78 seconds
Here’s another run:
->Start time: Mon Jun 15 15:18:04 2020
TransferPacket: Read failed (ret=0)
Gateware version mismatch!
Expected gateware version 2, revision 21
Test results: 1; 0; 0 - PASSED
->Si5351C test
CLK0: 2 / 17554 - FAILED
CLK1: 2 / 17554 - FAILED
CLK2: 2 / 17554 - FAILED
CLK3: 2 / 17554 - FAILED
CLK4: 2 / 17554 - FAILED
CLK5: 2 / 17554 - FAILED
CLK6: 2 / 17554 - FAILED
FAILED
->ADF4002 Test
Result: 0 - FAILED
FAILED
Results : 4 (min); 4 (max) - FAILED
FAILED
->Clock Network Test FAILED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencyCGEN(80 MHz) failed
Elapsed time: 2.18 seconds
I do not have anything hooked up to the board and I have tried it on a few different computers.
I tried to submit a RMA request for a replacement through the crowdsupply website, but it keeps getting a “400 Bad Request” error when I submit the form.
I’m willing to try anything that anyone can advise if they think it will help. I am running Windows 10, and I am also trying to get a linux box up and running for testing.
I have very limited experience with SDR’s, and recently graduated from the cheap $25 dongles to the LimeSDR. I purchased one for myself and one for my father who happens to be a HAM operator, and he’s interested in this tech.
Thanks,
Jeff Newbill
