Hi @Zack and other great help ful people.
Done some in depth testing here.
Most of the time i get “All Passed” from LimeQuickTest
BUT now i realize that i get two oddities
After A while , just connected by USB, with no usage, i can get:
C:\Users\foggy>LimeQuicktest
->Start time: Fri May 15 12:05:42 2020
TransferPacket: Read failed (ret=0)
Gateware version mismatch!
Expected gateware version 2, revision 21
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009081C05C42C3A, index=0
Serial Number: 0009081C05C42C3A
->FX3 GPIF clock test
Test results: 1; 0; 0 - PASSED
->Si5351C test
CLK0: 2 / 17554 - FAILED
CLK1: 2 / 17554 - FAILED
CLK2: 2 / 17554 - FAILED
CLK3: 2 / 17554 - FAILED
CLK4: 2 / 17554 - FAILED
CLK5: 2 / 17554 - FAILED
CLK6: 2 / 17554 - FAILED
FAILED
->ADF4002 Test
Result: 0 - FAILED
FAILED
Results : 4 (min); 4 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: 13 02 1A 13 02 1A 02
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencyCGEN(80 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.45 seconds
and just after a limeutil -update
in Limesuitegui i some times get:
[12:00:24] ERROR: TransferPacket: Read failed (ret=0)
[12:00:24] WARNING: Gateware version mismatch!
[12:00:24] INFO: Reference clock 10.00 MHz
[12:00:24] INFO: Connected Control port: LimeSDR-USB FW:4 HW:0 Protocol:1 GW:0.0 Ref Clk: 10.00 MHz
notice:
and if i do a limeutil -update i get
C:\Users\foggy>LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9081C05C42C3A]
Existing firmware is same as update (4)
Existing gateware is same as update (2.21)
Firmware and Gateware update is not required.
Programming update complete!
