I put this on hold for a little while but I did end up grabbing a different usb hub that has power attached to it.
One question, what is the maximum safe voltage that the board will accept? Can this be hooked up to a 10-16v auto circuit?
Snip--------------------------------------------------------------
nick@ipad:~$ LimeQuickTest
->Start time: Thu Jul 30 20:53:23 2020
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=00090726074E3527, HW=4, GW=2.23
Serial Number: 00090726074E3527
Chip temperature: 27 C
->FX3 GPIF clock test
Test results: 43986; 47742; 51498 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112929 (min); 5113063 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 1A 12 07 1A 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-13.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.4 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-18.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-22.4 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-15.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.66 seconds
SNIP---------------------------------------------------------------
nick@ipad:~$ sudo lsusb -t
[sudo] password for nick:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 5000M
|__ Port 4: Dev 3, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/7p, 480M
|__ Port 2: Dev 12, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 13, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 15, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 4: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 4: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 5: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 5: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
SNIP----------------------------------------------------------------------`
nick@ipad:~$ sudo lsusb -v -s 5
Bus 002 Device 005: ID 1d50:6108 OpenMoko, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x1d50 OpenMoko, Inc.
idProduct 0x6108
bcdDevice 0.00
iManufacturer 1 Myriad-RF
iProduct 2 LimeSDR-USB
iSerial 3 00090726074E3527
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 70
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 4
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 15
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 15
bLength 7
bDescriptorType 5
bEndpointAddress 0x0f EP 15 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x8f EP 15 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 3
Lowest fully-functional device speed is SuperSpeed (5Gbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
Device Status: 0x0000
(Bus Powered)
SNAP-----------------------------------------------------------
[Jul30 19:10] usb 2-2.3: USB disconnect, device number 5
[ +2.556449] usb 2-2.3: new SuperSpeed USB device number 6 using xhci_hcd
[ +0.014316] usb 2-2.3: LPM exit latency is zeroed, disabling LPM.
[ +0.000840] usb 2-2.3: New USB device found, idVendor=1d50, idProduct=6108
[ +0.000005] usb 2-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000003] usb 2-2.3: Product: LimeSDR-USB
[ +0.000003] usb 2-2.3: Manufacturer: Myriad-RF
[ +0.000003] usb 2-2.3: SerialNumber: 00090726074E3527
I notice this line:
is this saying it is disabling link power managment?
