en1gma@M4800:~$ LimeUtil --info
LimeSuite information summary
Version information:
Library version: v19.01.0-myriadrf1~bionic
Build timestamp: 2019-02-08
Interface version: v2019.1.0
Binary interface: 19.01-1
System resources:
Installation root: /usr
User home directory: /home/en1gma
App data directory: /home/en1gma/.local/share/LimeSuite
Config directory: /home/en1gma/.limesuite
Image search paths:
- /home/en1gma/.local/share/LimeSuite/images
- /usr/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
en1gma@M4800:~$ LimeUtil --find
- [LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF]
en1gma@M4800:~$ LimeQuickTest
->Start time: Thu Apr 11 07:56:23 2019
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF
Serial Number: 1D3BD0C4F0CDFF
->REF clock test
Test results: 48023; 61220; 8881 - PASSED
Results : 6711004 (min); 6711168 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 03 10 12 03 10 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-28.3 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-12.8 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.45 seconds
now my limesdr-mini was working perfect until i did a clean install of ubuntu 18.04.2 amd64 Desktop last night.
i also installed LimeSuite 19.01 (build-date = 2019-02-08) from Myriad PPA.
i then did the command ‘limesuite --update’ and it updated the firmware.
just wondering why i am now getting this RF Loopback error on (TX_2 -> LNA_W)
any info will help greatly.
thanks
i did have ubuntu 18.04.1 installed before this and was using limesuite 18.04 (i believe)
just wanted to add that i switched to my windows 10 64bit drive and it has PothosSDR-2019.03.24-vc14-x64.exe installed on it.
it fails limesuitegui calibrate all with same mcu error 4
if i want to go back to the firmware my lime-mini was using before (i think was 1.27) but maybe it was 1.24?
anyhow do i need to install a certain limesuite or pothosware to flash to lower gateware or can i just use this limesuite 19.01 to flash to lower gateware?
thanks
fixed my own problem by using windows 10 pothos 19.01 and downgrading fpga to 1.27
i then uninstalled pothos and installed pothos from 2018-11-04
calibration passes.
this has NOT fixed my problem.
although i can now successfully “Calibrate All” from within limesuite gui i am still failing RF Loopback Test with the LimeQuickTest program
