Hi everyone, I’m a full beginner with this kind of SDR and with FPGA in general. I know there is the same subject just before but I haven’t the same error.
Here the log :
[ TEST STARTED ]
->Start time: Thu Feb 16 11:11:07 2023
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=XXX, index=0
- Serial Number: XXX*
->REF clock test
- Test results: 1903; 4686; 7421 - PASSED*
->VCTCXO test - Results : 6710995 (min); 6711030 (max) - FAILED*
- FAILED*
->Clock Network Test FAILED
Operation failed: error code 5
->FPGA EEPROM Test FAILED
- Reg 0x20: Write value 0xFFFD, Read value 0xFFFD*
- Reg 0x20: value after reset 0x0FFFF*
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
->On board loopback test:
- Test 1:(SXR=1000.0MHz, SXT=1005.0MHz, TXPAD=8): Result:(-25.6 dBFS, 5.00 MHz) - FAILED*
->Run Tests (TX_1 → LNA_H):
->On board loopback test: - Test 1:(SXR=2100.0MHz, SXT=2105.0MHz, TXPAD=8): Result:(-20.7 dBFS, 5.00 MHz) - PASSED*
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 6.61 seconds
I have the latest version of LimeSuite GUI, but I want to know if the LimeSDR QucikTest is compatible with the new LimeSDR Mini v2.2? If yes, what i’m doing wrong ? (In advance, I don’t know how to flash the fpga)
