I have read several of the posts about the RF Loopback test failing, but none of them seem to propose a solution.
I have connected Antennas to the ports but still I get failure. ./LimeQuickTest
->Start time: Tue Sep 10 19:24:33 2024
->LimeSuite version: 22.09.0-ge829d3ed
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D40E13C0638D2, HW=2, GW=1.30
Serial Number: 1D40E13C0638D2
Chip temperature: 30 C
->REF clock test
Test results: 45490; 58687; 6348 - PASSED
Results : 6711022 (min); 6711189 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 06 1B 12 06 1B 03
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-19.7 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-26.7 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.65 seconds
