KC7NOA-Ibase@linux-7kco:~> Lime
LimeQuickTest LimeSuiteGUI LimeUtil
KC7NOA-Ibase@linux-7kco:~> LimeQuickTest
->Start time: Tue Mar 5 19:40:16 2019
Gateware version mismatch!
Expected gateware version 2, revision 18
But found version 2, revision 20
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060B00473825
Serial Number: 0009060B00473825
->FX3 GPIF clock test
Test results: 18619; 22375; 26131 - PASSED
->Si5351C test
CLK0: 17553 / 17554 - PASSED
CLK1: 17553 / 17554 - PASSED
CLK2: 17553 / 17554 - PASSED
CLK3: 17553 / 17554 - PASSED
CLK4: 17553 / 17554 - PASSED
CLK5: 17553 / 17554 - PASSED
CLK6: 17553 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112955 (min); 5113090 (max) - PASSED
->Clock Network Test PASSED
->Read data: 11 01 13 11 01 13 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
Read(64 bytes) failed
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-12.9 dBFS, 5.00 MHz) - PASSED
Write(64 bytes) failed
Failed to read samples: Timeout
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.0 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_W):
->Run Tests (TX_2-> LNA_H):
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 7.24 seconds
->Start time: Tue Mar 5 19:40:35 2019
Test results: 19922; 23678; 27434 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112956 (min); 5113091 (max) - PASSED
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-13.0 dBFS, 5.00 MHz) - PASSED
Elapsed time: 7.16 seconds
->Start time: Tue Mar 5 19:41:14 2019
Test results: 19026; 22782; 26538 - PASSED
->Si5351C test
->ADF4002 Test
Result: 10 - PASSED
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-13.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.3 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-13.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-18.8 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-18.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-11.8 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 1.59 seconds
after 4 plug, unplug cycles its working again … does this offten
