sdr@sdr-STORENGO:~/Pobrane/LimeSuite-RestructureLimeSuite/builddir$ SoapySDRUtil --probe
Probe device
linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_003.010.003.000-0-g423b4c19
[INFO] Make connection: ‘LimeSDR-USB [USB 3.0] 9061C02CA2B20’
[ERROR] Read(64 bytes) failed
Expected gateware version 2, revision 12
Lime Suite - Myriad-RF Wiki
[ERROR] Write(64 bytes) failed
[INFO] Reference: -1 MHz
[ERROR] SetFrequencyCGEN(80 MHz) failed
– Device identification
driver=FX3
hardware=LimeSDR-USB
boardSerialNumber=0x9061c02ca2b20
firmwareVersion=4
gatewareVersion=0.0
hardwareVersion=4
protocolVersion=1
– Peripheral summary
Channels: 2 Rx, 2 Tx
Timestamps: YES
Sensors: clock_locked, lms7_temp
Registers: BBIC, RFIC0
GPIOs: MAIN
– RX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream formats: CF32, CS12, CS16
Native format: CS16 [full-scale=2048]
Stream args:
* Buffer Length - The buffer transfer size over the link.
[key=bufferLength, units=samples, default=0, type=int]
* Link Format - The format of the samples over the link.
[key=linkFormat, default=CS16, type=string, options=(CS16, CS12)]
Antennas: NONE, LNAH, LNAL, LNAW, LB1, LB2
Corrections: DC removal
Full gain range: [-12, 61] dB
TIA gain range: [0, 12] dB
LNA gain range: [0, 30] dB
PGA gain range: [-12, 19] dB
Full freq range: [0, 3800] MHz
RF freq range: [30, 3800] MHz
BB freq range: [6.25e-08, -6.25e-08] MHz
Tune args:
[key=OFFSET, units=Hz, default=0.0, type=float]
[key=BB, units=Hz, default=DEFAULT, type=float, options=(DEFAULT, IGNORE)]
Sample rates: [0.1, 65] MSps
Filter bandwidths: [1.4, 130] MHz
Sensors: lo_locked
Other Settings:
* TSP DC Level - Digital DC level in LMS7002M TSP chain.
[key=TSP_CONST, type=int, range=[0, 32767]]
– RX Channel 1
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
– TX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream args:
Antennas: NONE, BAND1, BAND2
Full gain range: [-12, 64] dB
PAD gain range: [0, 52] dB
IAMP gain range: [-12, 12] dB
BB freq range: [2.5e-07, -2.5e-07] MHz
Tune args:
Filter bandwidths: [5, 40], [50, 130] MHz
Sensors: lo_locked
Other Settings:
– TX Channel 1
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
sdr@sdr-STORENGO:~/Pobrane/LimeSuite-RestructureLimeSuite/builddir$ LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9061C02CA2B20]
[100%] 562691/562691 Bytes programming: completed (/home/sdr/.local/share/LimeSuite/images/18.01/LimeSDR-USB_HW_1.4_r2.12.rbf)
Programming update complete!
Probe device
driver=FX3
firmwareVersion=4
gatewareVersion=0.0
hardwareVersion=4
protocolVersion=1
Timestamps: YES
GPIOs: MAIN
– RX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
– RX Channel 1
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
– TX Channel 0
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
– TX Channel 1
Full-duplex: YES
Supports AGC: NO
Stream args:
Tune args:
Sensors: lo_locked
Other Settings:
