HI ,
I have one board which fails in quick test and also gets very hot. Logs attached. Do anyone has idea what could possibly go wrong?
logs:
->Start time: Mon Dec 14 13:09:10 2020
Gateware version mismatch!
Expected gateware version 2, revision 23
But found version 2, revision 22
Lime Suite - Myriad-RF Wiki
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009081C05C1281D, index=0, HW=4, GW=2.22
Serial Number: 0009081C05C1281D
Chip temperature: 45 C
->FX3 GPIF clock test
Test results: 32315; 36071; 39827 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112941 (min); 5113081 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 01 18 13 01 18 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.6 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 → LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-43.3 dBFS, -20.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-20.3 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.0 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-15.3 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 6.61 seconds
->Start time: Mon Dec 14 13:22:44 2020
Chip temperature: 37 C
Test results: 27922; 31678; 35434 - PASSED
->Si5351C test
->ADF4002 Test
Result: 10 - PASSED
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.8 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-43.5 dBFS, -20.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-19.0 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.3 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-15.8 dBFS, 5.00 MHz) - PASSED
Elapsed time: 6.72 seconds
->Start time: Mon Dec 14 13:29:23 2020
Chip temperature: 34 C
Test results: 28795; 32551; 36307 - PASSED
->Si5351C test
->ADF4002 Test
Result: 10 - PASSED
Results : 5112941 (min); 5113080 (max) - PASSED
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-14.3 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-16.3 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-43.1 dBFS, -20.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-18.5 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-16.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-14.9 dBFS, 5.00 MHz) - PASSED
Elapsed time: 6.50 seconds
