Hi guys,
I’m completely new to Lime and RF so please bear with any especially boneheaded questions. I am having issues getting the Lime Suite tests to pass and to update firmware. I have run the tests first thing in the morning so the unit is cool and it is plugged directly into a USB 3.0 port with no antennas connected. The test results are below. I initially thought the issue was FW related so I tried to update that with LimeUtil and got the error below.
Is there something I am missing regarding setup? If it’s useful, when the SDR is plugged in and working the green light stays on and a red light flashes. I can read signals ok.
➜ ~ LimeUtil --update
Connected to [LimeSDR Mini [USB 3.0] 1DA160F0A4F7E8]
--2024-08-01 08:33:49-- https://downloads.myriadrf.org/project/limesuite/22.09/LimeSDR-Mini_HW_2.0_r2.2.bit
Resolving downloads.myriadrf.org (downloads.myriadrf.org)... 2a03:b0c0:1:d0::eed:8001, 165.227.233.124
Connecting to downloads.myriadrf.org (downloads.myriadrf.org)|2a03:b0c0:1:d0::eed:8001|:443... failed: Connection refused.
Connecting to downloads.myriadrf.org (downloads.myriadrf.org)|165.227.233.124|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2024-08-01 08:33:49 ERROR 404: Not Found.
Failed: wget --output-document="/home/richard/.local/share/LimeSuite/images/22.09/LimeSDR-Mini_HW_2.0_r2.2.bit" "https://downloads.myriadrf.org/project/limesuite/22.09/LimeSDR-Mini_HW_2.0_r2.2.bit"
Programming update failed!
LimeSuite tests:
➜ ~ LimeQuickTest
->Start time: Thu Aug 1 08:35:35 2024
->LimeSuite version: 22.09.0-ge829d3ed
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1DA160F0A4F7E8, HW=7, GW=0.31
Serial Number: 1DA160F0A4F7E8
Chip temperature: 45 C
->REF clock test
Test results: 21235; 22784; 24269 - PASSED
Results : 6711009 (min); 6711044 (max) - FAILED
FAILED
->Clock Network Test FAILED
Operation failed: error code 5
->FPGA EEPROM Test FAILED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-26.7 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-23.6 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.40 seconds
OS Detail:
➜ ~ uname -a
Linux debian 6.1.0-23-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.99-1 (2024-07-15) x86_64 GNU/Linux
