when i try to update
root@ubuntu:/home/ddyw# LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 90726074F2009]
Read(64 bytes) failed
Gateware version mismatch!
Expected gateware version 2, revision 21
Existing firmware is same as update (4)
Programming failed! Error Programming failed! Error (/usr/share/LimeSuite/images/19.04/LimeSDR-USB_HW_1.4_r2.21.rbf)
Programming update failed!
when i try to quick test
root@ubuntu:/home/ddyw# LimeQuickTest
->Start time: Thu Nov 28 02:58:22 2019
Write(64 bytes) failed
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=00090726074F2009
Serial Number: 00090726074F2009
->FX3 GPIF clock test
->FX3 GPIF clock test FAILED
->Si5351C test
FAILED
->ADF4002 Test
FAILED
FAILED
->Clock Network Test FAILED
->Read data: 12 08 02 12 08 02 02
->FPGA EEPROM Test PASSED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.50 seconds
LimesuitGUI does not work either
program failed either T_T
Help me plz,thanks a lot!
and tell me the URL to download the update tool.My limesuit version is
