Update Gets Successfull Driver is found ok on find command. But on connection with LimeSuite and LimeQuickTest it gets failed.
I have J17 installed as well.
LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9070602432019]
Gateware version mismatch!
Expected gateware version 2, revision 23
But found version 65535, revision 65535
Lime Suite - Myriad-RF Wiki
Existing firmware is same as update (4)
[100%] 579307/579307 Bytes programming: completed (/home/salik/.local/share/LimeSuite/images/23.11/LimeSDR-USB_HW_1.4_r2.23.rbf)
Programming update complete!
$ LimeUtil --find
- [LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009070602432019]
$ LimeQuickTest
->Start time: Tue Jul 30 17:13:14 2024
->LimeSuite version: 23.11.0-unknown
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009070602432019, HW=127, GW=65535.65535
Serial Number: 0009070602432019
Chip temperature: 45 C
->FX3 GPIF clock test
Test results: 65535; 65535; 65535 - FAILED
->FX3 GPIF clock test FAILED
->Si5351C test
CLK0: 65535 / 17554 - FAILED
CLK1: 65535 / 17554 - FAILED
CLK2: 65535 / 17554 - FAILED
CLK3: 65535 / 17554 - FAILED
CLK4: 65535 / 17554 - FAILED
CLK5: 65535 / 17554 - FAILED
CLK6: 65535 / 17554 - FAILED
FAILED
->ADF4002 Test
Result: 65535 - FAILED
FAILED
Results : 4294967295 (min); 4294967295 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: 12 03 02 12 03 02 02
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
TuneVCO(CGEN) - failed to lock (cmphl!=3)
SetFrequencyCGEN(61.44 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.46 seconds
