I have a fresh LimeSDR connected to my laptop running openSUSE Tumbleweed with limesuite 20.10.0-2.2. I’ve soldered on a connector for a fan as part of the aluminum case that I bought for it, but otherwise it is out of the box.
When I attempt to run the LimeQuickTest I get the following:
->Start time: Sun Nov 28 19:34:19 2021
->LimeSuite version: 20.10.0-release
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009081C05C30F34, HW=4, GW=2.23
Serial Number: 0009081C05C30F34
Operation not supported
Chip temperature: 0 C
->FX3 GPIF clock test
Test results: 22682; 26438; 30194 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112911 (min); 5113052 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 01 18 13 01 19 03
->FPGA EEPROM Test PASSED
RegistersTest() failed
->LMS7002M Test FAILED
SetFrequencyCGEN(61.44 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.12 seconds
Attempts to load the self_test.ini file from https://wiki.myriadrf.org/LimeSDR-USB_Quick_Test in LimeSuiteGUI result in the following console output:
[20:16:00] ERROR: SetFrequencySXR(7.89 MHz) - required VCO frequency is out of range [3800-7714] MHz
[20:16:00] ERROR: SetFrequencySXT(61.44 MHz) - cannot deliver frequency
[20:16:00] ERROR: TuneVCO(CGEN) - failed to lock (cmphl!=0)
[20:16:00] ERROR: SetPllFrequency: timeout, busy bit is still 1
[20:16:00] ERROR: LML RX phase search FAIL
[20:16:00] ERROR: LML TX phase search FAIL
This output is done when the device is connected cold, out of its case, with nothing attached (including the fan).
Can someone please identify what might be the problem? Do I have a defunct board?
Thanks!
