Hardware:LimeSDR
System:windows 10
software:LimeSuite GUI ver 19.04.0-PothosSDR-2019.06.09-vc14-x64
Yesterday,I Installed a new LimeSuite version(19.04.0),but when I Open the FFT Viewer, I can’t see any single wave, I noticed a hint below.(In previous versions, it was working normally.)
So,I clicked the buttons in turn.
I think I may have made a big mistake, because this module is not working properly now
Now I Open LimeSuite and connect LimeSDR. It looks like this:
Very desperate, really need help!
Test info:
->Start time: Thu Sep 19 11:06:51 2019
Write(64 bytes) failed
Gateware version mismatch!
Expected gateware version 2, revision 17
Lime Suite - Myriad-RF Wiki
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009070602501436, index=0
Serial Number: 0009070602501436
->FX3 GPIF clock test
->FX3 GPIF clock test FAILED
->Si5351C test
FAILED
->ADF4002 Test
FAILED
FAILED
->Clock Network Test FAILED
->Read data: 12 03 01 12 03 01 02
->FPGA EEPROM Test PASSED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 42.09 seconds
