I got my LimeSDR-USB, unpacked it, connected it to USB-3 port, updated the firmware with LimeUtil --update, then I try LimeQuickTest and sometimes I got something like this:
->Start time: Fri Jan 17 18:00:09 2020
Warning: Multiple devices detected, connecting to the first device
Read(64 bytes) failed
Gateware version mismatch!
Expected gateware version 2, revision 21
Undefined/Failure
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=000907060244273B
Serial Number: 000907060244273B
->FX3 GPIF clock test
Undefined/Failure
Undefined/Failure
->FX3 GPIF clock test FAILED
->Si5351C test
Undefined/Failure
FAILED
->ADF4002 Test
Write(64 bytes) failed
FAILED
FAILED
->Clock Network Test FAILED
->Read data: 12 0C 06 12 0C 06 02
->FPGA EEPROM Test PASSED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.17 seconds
But most of the time this:
->Start time: Mon Jan 20 09:32:21 2020
Test results: 31209; 34965; 38721 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112962 (min); 5113095 (max) - PASSED
->Clock Network Test PASSED
->LMS7002M Test PASSED
The manual (LimeSuiteGui) test also doesn’t work as I cant get pass the open ini file, which fails with the same error message. So what should I do?
