I am using LimeSDR under Mac OS. Upon launch of LimeSuiteGUI i receive following notification messages:
00:56:57] WARNING: Gateware version mismatch!
Expected gateware version 2, revision 8
But found version 2, revision 6
[00:56:57] INFO: Estimated reference clock 30.7197 MHz
[00:56:57] INFO: Selected reference clock 30.720 MHz
[00:56:57] INFO: Connected Control port: LimeSDR-USB FW:3 HW:4 Protocol:1 GW:2 GW_rev:6 Ref Clk: 30.72 MHz
As the notification tells, I try to update limeSDR firmware by either running ./LimeUtil --update or through LimeSuiteGUI -> programming. Both fails with a message like this one.
./LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9060B00492B0D]
[INFO] Estimated reference clock 30.7197 MHz
Programming update failed! : ProgramWrite length should be > 0
Please advise me on how should I start troubleshoot this?
