LimUtil --update scrogged - how to start over?
Got a new USB3.1 card installed, limesdr device found ok - anyway it look like an update failed and now I need to reprogram something manually?
All was OK:
root@OSCompute1:~# SoapySDRUtil --find
linux; GNU C++ version 4.8.4; Boost_105400; UHD_3.11.0.git-71-g2016126f
Found device 0
addr = 1d50:6108
driver = lime
media = USB
module = STREAM
name = USB 2.0 (LimeSDR-USB)
serial = 0009060B00471F23
Preparing to update to 17.01.1 (dry run with current version):
root@OSCompute1:~# LimeUtil --update
Connected to [USB 2.0 (LimeSDR-USB), media=USB, module=STREAM, addr=1d50:6108, serial=0009060B00471F23]
Estimated reference clock 30.7193 MHz
Selected reference clock 30.720 MHz
[ 20%] 36800/186040 Bytes Programming failed! Read operation failed (/root/.local/share/LimeSuite/images/17.01/LimeSDR-USB_HW_1.3_r3.0.img)
Programming update failed! : Programming failed! Read operation failed
Now I’m scrogged??
Feb 6 14:55:01 compute1 CRON[26062]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Feb 6 14:55:59 compute1 kernel: [ 9321.613179] usb 3-2: new high-speed USB device number 17 using xhci_hcd
Feb 6 14:55:59 compute1 kernel: [ 9321.613206] xhci_hcd 0001:58:00.0: ERROR: unexpected command completion code 0x0.
Feb 6 14:56:05 compute1 kernel: [ 9326.835714] usb 3-2: device descriptor read/8, error -110
Anything I do in LimeSuiteGUI for the programming gets segfault - kind of thrashing around without instructions :slight_smile: Plug the board in after powercycle nothing appears, but if I push the little button it at least appears as:
Found device 0
addr = 04b4:00f3
driver = lime
label = WestBridge [USB 2.0] 4BE
media = USB 2.0
module = STREAM
name = WestBridge
serial = 0000000004BE
In the above state:
root@OSCompute1:~# LimeUtil --fw=“/root/.local/share/LimeSuite/images/17.01/LimeSDR-USB_HW_1.3_r3.0.img”
Connected to [WestBridge [USB 2.0] 4BE]
Unsupported hardware connected: UNKNOWN[HW=0]
[ 0%] 0/186040 Bytes Programming failed! Write operation failed
Programming failed! : Programming failed! Write operation failed
hi @cswiger,
It looks like there was firmware update interrupt. Now FX3 MCU boots into bootloader mode.
You may try the following steps using LimeSuiteGUI:
  1. Download the latest firmware image file;
  2. Connect the LimeSDR board;
  3. Run LimeSuiteGUI and connect to the device;
  4. Go to Modules -> Programming menu;
  5. Select FX3 in Device list and Firmware to RAM in Programming mode. Open image file you downloaded in the step 1;
  6. Push Program and wait till programming is finished;
  7. Connect to the device again in LimeSuiteGUI. Now you will see it as usually;
  8. Perform step 4;
  9. Set everything as in step 5 just choose Firmware to Flash instead of Firmware to RAM in Programming mode;
  10. Push Program and wait till programming is finished.
Check if everything is OK by re-connecting the board.
Huh - no luck with that - In short, new usb3.1 card (ORICO 2 Ports USB3.1 Desktop Computer Board PCI-E) plugged into an hp xw9400 - brought up Ubuntu 14.04 “trusty” - plugged in power and connected lime board to the usb3.1 port. Finds it ok, started a LimeUtil --update and it starts - later find the above failure at 20%. At this point the usb card is deaf and responds to nothing else, until just recently restarted.
The Lime board shows nothing when plugged in by itself (no other power - the usb3 card takes an aux power from sata connectors) - and with power it we see this:
Feb 7 18:26:09 compute1 kernel: [ 418.474883] usb 3-2: new high-speed USB device number 3 using xhci_hcd
Feb 7 18:26:14 compute1 kernel: [ 423.493406] usb 3-2: device descriptor read/8, error -110
Feb 7 18:26:19 compute1 kernel: [ 428.615686] usb 3-2: device descriptor read/8, error -110
Feb 7 18:26:20 compute1 kernel: [ 428.886792] usb 3-2: new high-speed USB device number 4 using xhci_hcd
Feb 7 18:26:29 compute1 kernel: [ 433.888603] xhci_hcd 0001:58:00.0: Timeout while waiting for address device command
Feb 7 18:26:29 compute1 kernel: [ 438.494273] [sched_delayed] sched: RT throttling activated
Feb 7 18:26:29 compute1 kernel: [ 438.694414] usb 3-2: Device not responding to set address.
Feb 7 18:26:30 compute1 kernel: [ 438.898487] usb 3-2: device not accepting address 4, error -71
Feb 7 18:26:30 compute1 kernel: [ 438.899677] xhci_hcd 0001:58:00.0: Bad Slot ID 3
Feb 7 18:26:30 compute1 kernel: [ 438.899690] xhci_hcd 0001:58:00.0: Could not allocate xHCI USB device data structures
Feb 7 18:26:30 compute1 kernel: [ 438.899705] hub 3-0:1.0: couldn’t allocate port 2 usb_device
and the firmware update cannot even start. When powered and plugged into the previously working usb port we see this:
Feb 7 18:47:55 compute1 kernel: [ 1724.998005] usb 1-4: new high-speed USB device number 4 using ehci-pci
Feb 7 18:48:10 compute1 kernel: [ 1740.115855] usb 1-4: device descriptor read/64, error -110
Feb 7 18:48:26 compute1 kernel: [ 1755.337746] usb 1-4: device descriptor read/64, error -110
Feb 7 18:48:26 compute1 kernel: [ 1755.553783] usb 1-4: new high-speed USB device number 5 using ehci-pci
Feb 7 18:48:41 compute1 kernel: [ 1770.671661] usb 1-4: device descriptor read/64, error -110
Feb 7 18:48:56 compute1 kernel: [ 1785.893499] usb 1-4: device descriptor read/64, error -110
Feb 7 18:48:56 compute1 kernel: [ 1786.109622] usb 1-4: new high-speed USB device number 6 using ehci-pci
Feb 7 18:49:07 compute1 kernel: [ 1796.521591] usb 1-4: device not accepting address 6, error -110
Feb 7 18:49:07 compute1 kernel: [ 1796.633673] usb 1-4: new high-speed USB device number 7 using ehci-pci
Feb 7 18:49:17 compute1 kernel: [ 1807.045653] usb 1-4: device not accepting address 7, error -110
Feb 7 18:49:17 compute1 kernel: [ 1807.045747] hub 1-0:1.0: unable to enumerate USB device on port 4
Feb 7 18:49:18 compute1 kernel: [ 1807.501883] usb 2-4: new full-speed USB device number 4 using ohci-pci
Now -if I press the FX3 reset button we get this:
Feb 7 18:49:51 compute1 kernel: [ 1840.554636] usb 1-4: new high-speed USB device number 8 using ehci-pci
Feb 7 18:49:51 compute1 kernel: [ 1840.687508] usb 1-4: New USB device found, idVendor=04b4, idProduct=00f3
Feb 7 18:49:51 compute1 kernel: [ 1840.687521] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 7 18:49:51 compute1 kernel: [ 1840.687529] usb 1-4: Product: WestBridge
Feb 7 18:49:51 compute1 kernel: [ 1840.687535] usb 1-4: Manufacturer: Cypress
Feb 7 18:49:51 compute1 kernel: [ 1840.687540] usb 1-4: SerialNumber: 0000000004BE
Feb 7 18:49:51 compute1 mtp-probe: checking bus 1, device 8: “/sys/devices/pci0000:00/0000:00:02.1/usb1/1-4”
Feb 7 18:49:51 compute1 mtp-probe: bus: 1, device: 8 was not an MTP device
Interesting that the ‘event’ - whatever happened at 20% --update, took out the new usb3 card and we had to power off/on to recover it and it was just tested with a serial port usb device OK, but the Lime has not been able to be recovered.
One last datapoint - when the FX3 reset button is pressed the LimeUtil sees it but cannot update:
root@OSCompute1:~# LimeUtil --find
  • [WestBridge , media=USB 2.0, module=STREAM, addr=04b4:00f3, serial=0000000004BE]
Programming update failed! : Unsupported hardware connected: UNKNOWN[HW=0]
Hi @cswiger,
Have you tried the procedure described above (it is not clear from your response, sorry)? By the way, you have to use LimeSuiteGUI, not LimeUtil for this task.
Zack - after deep breath yes it was found in the LimeSuiteGUI OK , had to press the FX3 reset button, and now reloading. Thanks!! Apologies for the too much info :slight_smile:
Sure is a lot to learn here - I’m going to allocate a good 6 month period before even trying to pretend to know this device.
Just received my LimeSDR and tried to install the latest firmware. I almost immediately got “Programming failed”. Reason for updated was enumeration error, Any ideas what might be wrong?
Please read Update Firmware for LimeSDR v1.4 under windows
Thank you. Upgrade running right now.
Hi
i get below error but i don’t know about this. please help me.
libusb: warning [handle_timeout] async cancel failed -5 errno=22
