before running update, LimeUtil --find gave this output:
LimeUtil --find
- [LimeSDR-USB, media=USB 3.0, module=STREAM, addr=1d50:6108, serial=0009062A00CE131B]
I then proceed to do an update:
LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9062A00CE131B]
Expected gateware version 2, revision 8
But found version 2, revision 6
[INFO] Estimated reference clock 30.7197 MHz
–2017-07-31 11:39:10-- http://downloads.myriadrf.org/project/limesuite/17.06/LimeSDR-USB_HW_1.3_r3.0.img
Resolving downloads.myriadrf.org… 213.138.113.29, 2001:41c8:51:71d:fcff:ff:fe00:4203
Connecting to downloads.myriadrf.org|213.138.113.29|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 186040 (182K)
Saving to: ‘/Users/cjq/.local/share/LimeSuite/images/17.06/LimeSDR-USB_HW_1.3_r3.0.img’
/Users/cjq/.local/share/LimeS 100%[===================================================================>] 181.68K 34.2KB/s in 19s
2017-07-31 11:39:57 (9.42 KB/s) - ‘/Users/cjq/.local/share/LimeSuite/images/17.06/LimeSDR-USB_HW_1.3_r3.0.img’ saved [186040/186040]
–2017-07-31 11:39:57-- http://downloads.myriadrf.org/project/limesuite/17.06/LimeSDR-USB_HW_1.4_r2.8.rbf
Length: 562160 (549K)
Saving to: ‘/Users/cjq/.local/share/LimeSuite/images/17.06/LimeSDR-USB_HW_1.4_r2.8.rbf’
/Users/cjq/.local/share/LimeS 100%[===================================================================>] 548.98K 124KB/s in 5.1s
2017-07-31 11:40:03 (108 KB/s) - ‘/Users/cjq/.local/share/LimeSuite/images/17.06/LimeSDR-USB_HW_1.4_r2.8.rbf’ saved [562160/562160]
[100%] 562160/562160 Bytes programming: completed (/Users/cjq/.local/share/LimeSuite/images/17.06/LimeSDR-USB_HW_1.4_r2.8.rbf)
Programming update complete!
However, after running the update, LimeUtil --find gives this output:
LimeUtil --find
- [WestBridge , media=USB 2.0, module=STREAM, addr=04b4:00f3, serial=0000000004BE]
If I try to run update again, I get a weird error:
LimeUtil --update
Connected to [WestBridge [USB 2.0] 4BE]
[ERROR] Unsupported hardware connected: UNKNOWN[HW=0]
Programming update failed! : Unsupported hardware connected: UNKNOWN[HW=0]
