Hi all,
I made a fresh install of Ubuntu 18.04 Mate and added successfully Gnuradio Compagnion, LimeSuite Gui en Limeutils, gr-limesuite. Gnu radio is working fine, the RX source Limesuite is correctly finding the LimeSdr USB3
I installed also Gqrx and selected device “Other” and device string “soapy=0,driver=lime” input rate 5000000 bandwidth 100,000000M.
It worked at the first attempt.
Then I tried to use the LimeSdr instaed of “Other” since then nothing is working anymore: I restores the device “Other” with his settings, but no result:
I have a waterfall and signal strength screen probably working correctly, but obviously the program did not connect the lime.
Here part of the output during startup of the program:
Controlport disabled
No user supplied config file. Using “default.conf”
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5git) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd plutosdr miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
FM demod gain: 3.05577
Resampling audio 96000 -> 48000
IQ DCR alpha: 1.04166e-05
Using audio backend: autoControlport disabled
FM demod gain: 3.05577Controlport disabled
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5gitControlport disabled
BookmarksFile is /home/freddy/.config/gqrx/bookmarks.csv
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (hw:0,0), Device or resource busy.
) gnuradio 3.7.11
Some of you has a clue of how to resolve this ?
Thank you very much for your time!
Freddy, ON7VQ
