hi everyone, I am new with Ubuntu.
Following all the instructions and able to connect to LimeSDR through limesuite gui but not able to connect through GQRX, any help would be highly appreciated.
Using the default device string and getting the following errors
addr=1d50:6108,driver=lime,media=‘USB 3.0’,module=STREAM,name=LimeSDR-USB,serial=0009062000C51B1B,soapy=0
gqrx
linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_003.010.002.000-release
Controlport disabled
No user supplied config file. Using “default.conf”
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5git) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd plutosdr miri hackrf bladerf rfspace airspy soapy redpitaya
FM demod gain: 3.05577
Resampling audio 96000 -> 48000
IQ DCR alpha: 1.04166e-05
Using audio backend: auto
BookmarksFile is /home/rw/.config/gqrx/bookmarks.csv
getDeviceList : Available input devices:
0 : “PlutoSDR”
1 : “RFSPACE SDR-IQ Receiver”
2 : “RFSPACE SDR-IP Receiver”
3 : “RFSPACE NetSDR Receiver”
4 : “RFSPACE Cloud-IQ Receiver”
5 : “LimeSDR-USB [USB 3.0] 9062000C51B1B”
6 : “RTL-SDR Spectrum Server”
7 : “Red Pitaya Transceiver Server”
8 : “Complex Sampled (IQ) File”
Loading configuration from: “default.conf”
Configuration file: “/home/rw/.config/gqrx/default.conf”
Crash guard triggered!
Launching I/O device editor
firstTimeConfig
CIoConfig : Available output devices:
0 : “Built-in Audio Analog Surround 2.1”
saveConfig
Output device 1 : “alsa_output.pci-0000_00_1f.3.analog-surround-21”
Loading configuration from: “/home/rw/.config/gqrx/default.conf”
[INFO] Make connection: ‘LimeSDR-USB [USB 3.0] 9062000C51B1B’
[INFO] Estimated reference clock 30.7198 MHz
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
[INFO] LMS7002M cache /home/rw/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=82, FRAC=349525, DIV_OUTCH_CGEN=15
M=156, N=3, Fvco=1040.000 MHz
16: 01 A0 AA
16: FE AF 2A
phase: min 26.0; max 197.3; selected 111.6)
M=182, N=7, Fvco=1040.000 MHz
85: AA 5A 75
16: AA 52 D5
phase: min 10.4; max 176.5; selected 93.5)
16: FF AF AA
16: AB AA 3C
16: 57 8D 3B
16: 2A DC 7D
16: AA 52 D5
phase: min 15.6; max 176.5; selected 96.1)
[INFO] Rx Filter calibrated from cache
[INFO] Tx Filter calibrated from cache
phase: min 5.2; max 360.0; selected 182.6)
FATAL: destination port 1 out of range for source_impl(47)
Trying to fill up 18446744073709551615 missing channel(s) with null source(s).
due to gnuradio bug #528.
terminate called after throwing an instance of ‘std::invalid_argument’
what(): destination port 2 out of range for source_impl(47)
Aborted (core dumped)
