Well, today it is 100% reliable. Have sdrangel working as well. Though this does remind me of linux from scratch or gentoo with the amount of compiling I have to do…
Has anything changed between tests failing and passing? E.g. connections to the RF ports. When running the tests nothing should be connected to them. In any case, keep us posted.
Today I get failure on both the RX and TX test ->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-20.8 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-49.7 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
That’s with both the included antennae attached, or with no antennae.
However, even though it says it failed, it does appear to be working ok with SDRangel, gqrx and gnuradio with Fedora. Admittedly I haven’t done much with it yet though.
It seems to behave the same no matter whether I just plug it in or it’s been running for a while. It’s just that the tests fail, though now the device appears to work fine in all the rx tools. Haven’t tried tx yet.
Disconnected for 20 mins or so and temp went down to 24/26. Still failed result on both above. Admittedly I don’t know what the prerequistes for a TX_2 -> LNA_W test or a TX_1 -> LNA_H actually are!
Could you tell me exactly what you want me to provide, with or without antennae attached, etc? Cool (immediately after plugging in) or hot or both. Thanks!
TX_1 -> LNA_H is clearly failing on your board while TX_2 -> LNA_W is on the edge hence sometimes it is OK, sometimes fails.
Contact CrowdSupply for replacement.
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3BD0C4F0CDFF, HW=1, GW=1.30
Serial Number: 1D3BD0C4F0CDFF
Chip temperature: 43 C
->REF clock test
Test results: 57577; 5238; 18435 - PASSED
Results : 6710994 (min); 6711159 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 03 10 12 03 10 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
20.07.2-myriadrf1~focal amd64 (build date: 2020-08-06)
i did have a terminator on tx and a clear tv antenna you hang in a window.
sorry for the delay in my answer
i have done test before without tx and rx terminated (just open) and i have done test with both tx and rx terminated. with pretty much same result if i remember correct.
i can do any suggestion you want me to do just ask.
