I received a new LimeSDR-mini a few days ago. I installed LimeSuite, updated the firmware, etc. But I get always failures when I run the LimeQuickTest. Could someone please let me know if my new device is broken? Or is the output expected like that? Or do I miss a configuration setting? I tested on Ubuntu Linux and Mac OSX. Same results.
LimeQuickTest
->Start time: Thu Sep 13 09:24:26 2018
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D3AC9D15FAE3A
Serial Number: 1D3AC9D15FAE3A
->REF clock test
Test results: 65041; 12702; 25899 - PASSED
Results : 6711016 (min); 6711173 (max) - PASSED
->Clock Network Test PASSED
->Read data: 00 00 00 12 06 1A 07
->FPGA EEPROM Test FAILED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-22.2 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-13.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.55 seconds
Thank you very much in advance.
Best regards
