OK, some progress made. I now see the spectrum and waterfall plots, but its
still not working right.
Here are the steps I’m using:
1: Plug the LimeSDR Mini into USB 2 port.
2: In a terminal, enter: gqrx -r
3: The Configure I/O Devices window pops up, with ‘Complex Sampled IQ file’
pre-selected in the DEVICE field.
4: Change this to LimeSDR Mini [USB 2.0].
5: The DEVICE STRING field changes to:
addr=24607:1027,driver=lime,media=‘USB 2.0’,module=uLimeSDR,
name=‘LimeSDR Mini’,serial=1D3AD6********,soapy=2
6: The other fields are:
INPUT RATE: 5000000
DECIMATION: none
BANDWIDTH: 0.000000MHz
LNB LO: 0.000000MHz
7: Pressing the Play button does nothing, and ‘No audio FFT data’ starts scrolling
on the terminal window. The Antenna field is blank and can’t be altered.
8: Now, changing the DEVICE STRING field to ‘device=lime,soapy=2’, the spectrum
and waterfall plots appear. Cool!
But I’m not sure what I’m looking at. The spectrum plot looks the same, no matter what
frequency I set. I should be seeing strong local signals in the FM band, but I don’t.
Something else is missing.
Thanks for the help this far.
John.
---------- gqrx output messages ----------
$ gqrx -r
linux; GNU C++ version 7.3.0; Boost_106501; UHD_003.010.003.000-0-unknown
Controlport disabled
No user supplied config file. Using “default.conf”
“/home/john/.config/gqrx/default.conf” deleted
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
FM demod gain: 3.05577
Resampling audio 96000 -> 48000
IQ DCR alpha: 1.04166e-05
Using audio backend: auto
BookmarksFile is /home/john/.config/gqrx/bookmarks.csv
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (hw:0,0), Device or resource busy.
getDeviceList : Available input devices:
0 : “RFSPACE SDR-IQ Receiver”
1 : “RFSPACE SDR-IP Receiver”
2 : “RFSPACE NetSDR Receiver”
3 : “RFSPACE Cloud-IQ Receiver”
4 : “hw:HDA Intel PCH,0”
5 : “default”
6 : “LimeSDR Mini [USB 2.0] 1D3AD633012E13”
7 : “RTL-SDR Spectrum Server”
8 : “Red Pitaya Transceiver Server”
9 : “Complex Sampled (IQ) File”
Loading configuration from: “default.conf”
Configuration file: “/home/john/.config/gqrx/default.conf”
No change in output device:
old:
new:
New FFT rate: 25 Hz
Requested bandwidth: 0 Hz
Actual bandwidth : 0 Hz
setFreqCorr : 0 ppm
New LNB LO: 0 Hz
updateHWFrequencyRange failed fetching new hardware frequency range
New mode index: 2
Filter preset for mode 2 LO: -5000 HI: 5000
Generating taps for new filter LO:-5000 HI:5000 TW:2000 Taps: 115
setFftRate to “25 fps”
New FFT rate: 25 Hz
New FFT rate: 25 Hz
setFftSize to “8192”
New FFT rate: 25 Hz
Launching I/O device editor
firstTimeConfig
CIoConfig : Available output devices:
0 : “Built-in Audio Analog Stereo”
New input device selected: 1
Label: “LimeSDR Mini [USB 2.0] 1D3AD633012E13”
Devstr: “addr=24607:1027,driver=lime,media=‘USB 2.0’,module=uLimeSDR,name=‘LimeSDR Mini’,serial=1D3AD633012E13,soapy=2”
saveConfig
Loading configuration from: “/home/john/.config/gqrx/default.conf”
[INFO] Make connection: ‘LimeSDR Mini [USB 2.0] 1D3AD633012E13’
[INFO] Device name: LimeSDR-mini
[INFO] Reference: 40 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=63, FRAC=0, DIV_OUTCH_CGEN=15
CGEN: Freq=61.44 MHz, VCO=2.4576 GHz, INT=60, FRAC=461373, DIV_OUTCH_CGEN=19
M=156, N=3, Fvco=1040.000 MHz
MCU programming : 16384/16384
MCU Programming finished, 2501 ms
[ERROR] MCU working too long 4
[ERROR] setBandwidth(Rx, 0, 30 MHz) Failed -
FATAL:
Trying to fill up 1 missing channel(s) with null source(s).
due to gnuradio bug #528.
old:
new:
Failed to set RX input rate to 5e+06
Your device may not be working properly.
IQ DCR samp_rate: 5e+06
IQ DCR alpha: 2e-07
Changing NB_RX quad rate: 96000 -> 5e+06
Requested sample rate: 5000000
Actual sample rate : “5000000.000000”
New FFT rate: 25 Hz
setFreqCorr : 0 ppm
New LNB LO: 0 Hz
New mode index: 2
New FFT rate: 25 Hz
New FFT rate: 25 Hz
New FFT rate: 25 Hz
