Here are the logs until the crash:
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5git) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp miri hackrf bladerf rfspace airspy soapy redpitaya
Resampling audio 96000 -> 48000
gr::fft: can’t import wisdom from /home/justinslatten/.gr_fftw_wisdom
BookmarksFile is /home/justinslatten/.config/gqrx/bookmarks.csv
[INFO] Make connection: ‘USB 3.0 (LimeSDR-USB)’
Estimated reference clock 30.7197 MHz
Selected reference clock 30.720 MHz
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
LMS7002M values cache at /home/justinslatten/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.4 GHz, INT=77, FRAC=131072, DIV_OUTCH_CGEN=14
[INFO] SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Tx, 0, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 0, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 0, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 0, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=20MHz, rx=10MHz)
----- FPGA PLL #0 CONFIG -----
M=112, N=7, Fvco=640.000 MHz
C0=16, Fout=40.000 MHz, CNT_IND=2, nSteps=0, phaseShift=0.0
C1=16, Fout=40.000 MHz, CNT_IND=3, nSteps=35, phaseShift=98.4
----- FPGA PLL #1 CONFIG -----
M=93, N=3, Fvco=620.000 MHz
C0=31, Fout=20.000 MHz, CNT_IND=2, nSteps=0, phaseShift=0.0
C1=31, Fout=20.000 MHz, CNT_IND=3, nSteps=78, phaseShift=113.2
[INFO] SoapyLMS7::setSampleRate(Tx, 0, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=10MHz, rx=10MHz)
C1=31, Fout=20.000 MHz, CNT_IND=3, nSteps=65, phaseShift=94.4
[INFO] SoapyLMS7::setBandwidth(Rx, 0, 30 MHz)
[INFO] Rx Filter calibrated from cache
[INFO] SoapyLMS7::setBandwidth(Tx, 0, 30 MHz)
[INFO] Tx Filter calibrated from cache
[INFO] SoapyLMS7::setFrequency(Rx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Rx, 1, LNAL)
[INFO] SoapyLMS7::setAntenna(Tx, 1, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 1, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 1, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 1, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
[INFO] SoapyLMS7::setSampleRate(Tx, 1, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
[INFO] SoapyLMS7::setBandwidth(Rx, 1, 30 MHz)
[INFO] SoapyLMS7::setBandwidth(Tx, 1, 30 MHz)
FATAL: destination port 1 out of range for source_impl(47)
Trying to fill up 18446744073709551615 missing channel(s) with null source(s).
due to gnuradio bug #528.
terminate called after throwing an instance of ‘std::invalid_argument’
what(): destination port 2 out of range for source_impl(47)
Aborted (core dumped)
