Hi there,
I am an absolute newbie with this, but I hope you can still help me.
Just received my first ever LimeSDR in the Mail, which is the new v2. Spent the rest of the day trying to get it to work, but something seems off.
When I try to run LimeQuickTest, this ist the output:
LimeQuickTest
->Start time: Mon Feb 13 17:07:33 2023
->LimeSuite version: 22.09.1-release
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D90F98A571960, HW=5, GW=0.30
Serial Number: 1D90F98A571960
Chip temperature: 48 C
->REF clock test
Test results: 33427; 36744; 40062 - PASSED
Command not supported
FAILED
->Clock Network Test FAILED
Operation failed: error code 2
->FPGA EEPROM Test FAILED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-29.3 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-23.0 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.50 seconds
I just installed LimeSuite using Mac Ports as described here: Installing Lime Suite on macOS - Myriad-RF Wiki
So there is a lot of errors and I have no idea where to start debugging.
Is this normal and if not, do you have any suggestions where to start fixing this?
Thank you so much!
