Hello!
We are trying to run tests with a LimeSDR mini v1.3 on Ubuntu 20.04. We have installed everything, including the LimeSuite version and other related components, but when running LimeQuickTest we encounter issues. We are using version 20.01, but along with my colleagues, we have tried other versions with similar results. Could someone recommend the optimal version and check if there is anything strange based on the errors that LimeQuickTest throws?
Below is the output when running LimeQuickTest:
->Start time: Wed Feb 28 14:40:14 2024
->Device: LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1DA153DE25554DF
Warning: USB3 not available
Serial Number: 1DA153DE25554DF
->REF clock test
Test results: 65535; 65535; 65535 - FAILED
->REF clock test FAILED
Results : 4294967295 (min); 4294967295 (max) - FAILED
FAILED
->Clock Network Test FAILED
->Read data: FF FF FF FF FF FF FF
->FPGA EEPROM Test FAILED
RegistersTest() failed
->LMS7002M Test FAILED
TuneVCO(CGEN) - failed to lock (cmphl!=3)
SetFrequencyCGEN(61.44 MHz) failed
SetFrequencyCGEN(122.88 MHz) failed
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.60 seconds
