I could use some help here if someone has any ideas.
Noob to SDR, and LimeSDR. Ordered a Mini, HW version 1.3. Running the latest Windows 10 build 1909 with PothosDev environment & associated software - including LimeSuite tools. Plugged in first factory fresh LimeSDR Mini, installed driver - no issues, all according to wikis.
Tried running a quick test. See log below. Essentially, it just refused to run anything. But the board was detected properly.
->Start time: Thu Jun 4 18:53:33 2020
Command not supported
->Device: LimeSDR Mini, media=USB 3, module=FT601, serial=1D589735BC01D5, index=0
Serial Number: 1D589735BC01D5
->REF clock test
->REF clock test FAILED
FAILED
->Clock Network Test FAILED
Operation failed: error code 2
->FPGA EEPROM Test FAILED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 6.58 seconds
Next, tried an update via cmd line using LimeUtil. It gets to about 22%, then the programming fails.
Also even tried reprogramming the EEPROM. Thats failing too. Its like there is just no data connection or the FPGA isnt booting properly.
Any help or suggestions would be appreciated! Thanks!
