I am connecting Limesdr Mini to pc usb3 slot . But İt is writting usb2 . I am connecting limesdr mini with usb3 cable to pc usb3 slot but İt is writting usb2 . Why I dont understand Please Help ?
This is usb3 port connect informations I connected to usb3 port but it is seeing usb2 :S
Why You Know
root@kali:~/Downloads# uhd_find_devices
[INFO] [UHD] linux; GNU C++ version 9.2.1 20191109; Boost_106700; UHD_3.14.1.1-1+b1
[ERROR] avahi_service_browser_new() failed: Bad state
– UHD Device 0
Device Address:
serial: 1D4C3893CE8AAC
addr: 24607:1027
driver: lime
label: LimeSDR Mini [USB 2.0] 1D4C3893CE8AAC
media: USB 2.0
module: FT601
type: soapy
root@kali:~/Downloads# uhd_usrp_probe
[INFO] [UHDSoapyDevice] Make connection: ‘LimeSDR Mini [USB 2.0] 1D4C3893CE8AAC’
[INFO] [UHDSoapyDevice] Reference clock 40.00 MHz
[INFO] [UHDSoapyDevice] Device name: LimeSDR-Mini
[INFO] [UHDSoapyDevice] Reference: 40 MHz
[INFO] [UHDSoapyDevice] LMS7002M calibration values caching Disable
| Device: FT601
| _____________________________________________________
| | Mboard: LimeSDR-Mini
| | boardSerialNumber: 0x1d4c3893ce8aac
| | firmwareVersion: 6
| | gatewareVersion: 1.30
| | hardwareVersion: 2
| | protocolVersion: 1
| | Time sources:
| | Clock sources:
| | Sensors: clock_locked, lms7_temp
| | | RX DSP: 0
| | | Freq range: -10.000 to 10.000 MHz
| | | RX Dboard: 0
| | | | RX Frontend: 0
| | | | Antennas: NONE, LNAH, LNAL_NC, LNAW, Auto
| | | | Sensors: lo_locked
| | | | Freq range: 30.000 to 3800.000 MHz
| | | | Gain range TIA: 0.0 to 12.0 step 0.1 dB
| | | | Gain range LNA: 0.0 to 30.0 step 0.1 dB
| | | | Gain range PGA: -12.0 to 19.0 step 0.1 dB
| | | | Bandwidth range: 1400000.0 to 130000000.0 step 0.0 Hz
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | RX Codec: 0
| | | | Gain Elements: None
| | | TX DSP: 0
| | | TX Dboard: 0
| | | | TX Frontend: 0
| | | | Antennas: NONE, BAND1, BAND2, Auto
| | | | Sensors: lo_locked
| | | | Gain range PAD: 0.0 to 52.0 step 0.1 dB
| | | | Gain range IAMP: -12.0 to 12.0 step 0.1 dB
| | | | Bandwidth range: 5000000.0 to 130000000.0 step 10000000.0 Hz
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | TX Codec: 0
| | | | Gain Elements: None
