Since upgrading to the last firmware (20.10) my LimeSDR Mini works only as USB 2.0 device, even in USB 3.0 ports (where it worked until the update).
Also, the LimeQuickTest fails:
->Start time: Thu Jan 14 00:17:20 2021
->LimeSuite version: 20.10.0+dfsg-2
->Device: LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D589734EF6407, HW=3, GW=1.30
Warning: USB3 not available
Serial Number: 1D589734EF6407
Chip temperature: 34 C
->REF clock test
Test results: 41801; 54998; 2659 - PASSED
Results : 6711068 (min); 6711221 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 17 13 0A 17 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-21.2 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-20.5 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.15 seconds
if I downgrade to version 1.28 or lover (and use an older LimeQuickTest) the test is succesull every single time, although the LimeSDR Mini is still not recognised as USB 3.0:
->Start time: Thu Jan 14 09:39:59 2021
->REF clock test
Test results: 19964; 33161; 46358 - PASSED
Results : 6711088 (min); 6711241 (max) - PASSED
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-16.1 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.6 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.82 seconds
It appears that the device works despite this, but i haven’t tested it thoroughly.
I also tested the LimeSDR Mini on other USB 3.0 laptops and on neither is it recognized as a USB 3.0 device.
Something else that I found is that I receive an error if I try to upload the configuration from LimeSuiteGUI to the device (using the GUI → Chip button). It only fails with the new (20.10) version.
On older versions it works.
Any help is appreciated.
Thanks,
Werni
