Hi @Zack , I have a problem with my factory fresh LimeSDR mini not passing the LimeQuickTest.
I have a functioning unit (1) that passes and a failing unit (2).
Logs below.
Also to note : when I plug in unit 1 into an USB3 port, the LEDs glow alternately amber/yellow and red but when I plug in unit 2, the LEDs glow a solid green.
What should I check for on unit 2 ?
-------------------------- OK UNIT 1 LOGS ------------------------------
#LimeQuickTest
->Start time: Thu Feb 7 19:38:03 2019
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D42336356BE75
Serial Number: 1D42336356BE75
->REF clock test
Test results: 52791; 452; 13649 - PASSED
Results : 6711057 (min); 6711213 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 18 12 07 18 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-13.5 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-13.1 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.50 seconds
-------------------------- FAILING UNIT 2 LOGS ------------------------------
#LimeQuickTest
->Start time: Thu Feb 7 19:39:03 2019
Command not supported
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D4233D4AA7352
Serial Number: 1D4233D4AA7352
->REF clock test
->REF clock test FAILED
FAILED
->Clock Network Test FAILED
Operation failed: error code 2
->FPGA EEPROM Test FAILED
SPI_write() failed
SPI_write() failed
SPI_write() failed
->LMS7002M Test FAILED
Failed to set sample rate
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 0.86 seconds
