Hi all,
It’s been about a month since I got my long-awaited LimeSDR Mini board, but I haven’t been able to get it working with any of the popular SDR apps so far. None seem to be able to tweak the board into a working configuration, and it seems there are bandwidth issues somewhere along the data pipeline.
I’ve upgraded the firmware and the board seems to respond ok in LimeSuiteGUI. LimeQuickTest reports success. I use the limesuite-git and soapysdr-git AUR packages on an up-to-date Arch Linux box, and just rebuilt them all from their respective master branches. An Airspy Mini and a bunch of other dongles work fine with CubicSDR and qspectrumanalyzer over soapysdr. However, with the LimeMini CubicSDR just freezes for a few seconds before starting to dump a constant stream of
SDRThread::readStream(): 2. SoapySDR read failed with code: -1
SDRThread::readStream(): 3.1 iqDataOutQueue output queue is full, discard processing of the batch...
gqrx just bails with
gr-osmosdr v0.1.4-98-gc653754d (0.1.5git) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
[INFO] Make connection: 'LimeSDR Mini [USB 3.0] 1D3AC6EEA46E50'
[INFO] Reference: 4e+07 MHz
FATAL: SoapyLMS7::setupStream() failed:
Trying to fill up 1 missing channel(s) with null source(s).
due to gnuradio bug #528.
By fiddling with the settings in LimeSuiteGUI I was able to get 50Mbit/s over my USB 3.0 port in “FFTviewer”, so it can be made to work. I am left to think that some of the controls don’t get set correctly by some component in the Application -> Soapy -> Lime -> HW chain.
This has not been fun so far, and it’s a pity the Mini doesn’t have its own dedicated forum, tutorials and examples. Are there sample configurations somewhere one can easily try?
Examples of soapy device strings to configure a working mini board?
