I’ve just got my LimeSDR mini. However, I’m not able to get any signal out of it.
I tried gqrx, pothos fm example, the ‘made simple part 4’ pothos example, and the LimeSuite. I just get noise…
To make sure the hw is fine, I run the LimeSDR tester which can be found in of the other threads.
The fw is already up-to-date. I’m using it with a 2,4/5 GHz WiFi antenna. Although this is not the best choise for FM radio (90-18MHz in germany), it should at least work.
I know this is very little information to start debugging. Which further information do you need?
Found device 0
addr = 24607:1027
driver = lime
label = LimeSDR Mini [USB 3.0] 1D3AC710636CDD
media = USB 3.0
module = FT601
name = LimeSDR Mini
serial = 1D3AC710636CDD
I installed LimeSuite, Soapy, and Pothos from the respective Ubuntu repositories:
Not sure if you tried Gqrx with the default device, which doesn’t seem to work. So if you could try it with a device type of other and string “driver=lime,soapy=0”.
Yes, I tried it. Doesn’t work either. I just get noise.
I even switch the antenna to LNAW, because LNAL_NC is not supported on LimeSDR mini: “[WARNING] LNAL has no connection to RF ports”.
Here’s the console ouput of gqrx (I did switched the antenna.):
CGEN: Freq=128 MHz, VCO=2,304 GHz, INT=56, FRAC=629145, DIV_OUTCH_CGEN=8
IQ DCR samp_rate: 1e+06
IQ DCR alpha: 9.99999e-07
Changing WFM RX quad rate: 1e+07 → 1e+06
Generating taps for new filter LO:-80000 HI:80000 TW:32000 Taps: 19
Rx calibration using INTERNAL loopback
Rx ch.A @ 106,7 MHz, BW: 5 MHz, RF input: LNAW, PGA: 18, LNA: 1, TIA: 2
Current MCU firmware: 5, DC/IQ calibration full
MCU Ref. clock: 40 MHz
[INFO] Rx calibration finished
RX | DC | GAIN | PHASE
I: | 4 | 2046 | 16
Q: | 0 | 2047 |
Duration: 132 ms
Change your bandwidth to about 50 mhz and sample rate should be 5msps to 10 msps. The low bandwidth setting is probably the issue. For the mini I set my bandwidth to 50mhz and sample rate to 5 msps. If that doesn’t work raise your bandwidth to 60mhz. Hope this helps
